Clutch Replacement 07 525Xi 6-speed E60 Flywheel compatibility
Probation Members
My Ride: 2007 BMW 525XI 6-Speed
I have been looking everywhere and cant find this answer I have my car apart because I need to change theclutch it was completely smoked and ive got down to the flywheel and it looks like my DMF failed and i need to replace that also I have the new clutch kit but i dont have the $$ to dump a new flywheel into this car it just isnt worth it
I have called around and found a bunch of used car junkyards that have flywheels and i used BMWfans.info to find a lot of models that have the same flywheel the problem is no where states if I can use a flywheel from a Automatic in my car which is a 6-speed the lady at the junkyard said the system didnt say it was compatibile but she also didnt see any other models flywheel's as being compatible in her system which is not true according to bmwfans website
EDIT Reason i need auto is no where carries this car in 6speed so my best chance to find a flywheel is from a automatic car
so if anyone can help me i would appreciate it
Similar to BMWFans is Realoem.com if you haven't looked there also.
I very much doubt you can use a flywheel from an automatic. Rockauto has the LUK part for $452.
