CIC Retrofit Installation LOG
Old Feb 20, 2011 | 10:42 PM
  #471
r9ndy's Avatar
My Ride: 2005 545i Black Sapphire - Fully Loaded
Model Year: 545i 2005
Originally Posted by lopealle
Can you guys post pics of CIC retrofits on E60 M5s with heated/cooled/active seats. I'm not sure where you guys relocated the buttons for it. I would appreciate it thanks.
you can reuse the existing trim that is currently on there..
Old Feb 21, 2011 | 06:31 AM
  #472
nelson29's Avatar
My Ride: 2005 530i Silver Gray/ Gray Leather. SP,PP
Originally Posted by merkava74
Hi Nelson, could I have the part number for the above photo? Thanks!
51458037220.
Im hoping you not trying to buy it, it would not work...
Old Feb 21, 2011 | 07:11 AM
  #473
merkava74's Avatar
Originally Posted by nelson29
51458037220.
Care to share why? I currently have a 2007 Aug LCi E60, and the trim that I have comes with a hole at the top, like a storage compartment. After retrofitting the CiC, the CiC is exposed, and I figured the trim you showed is the answer. Currently, I customed a leather wrap in place of the hole, so it still looks ok. Will try to post some photos.
Separately, I seem to be having some problems with my Dension GW500 (I sent you an email on that... sorry to have to bother you so). I am able to hear the music from my iPod, but the screen doesn't show the artists or song name or album. It just goes on an infinite loop with the status bar thingy, and a greyed out line saying "please wait..."
This is when I set the Dipswitches to #1,2,6 as per Text enabled E60.
Then I tried to use the configuration for E90 with iDrive-4 (#2,3,4,6). Same.
By a stroke of frustration, I tried every single combination and voila, it recognised the Porsche PCM config (#2,3,6)! While most functions work, I get an "unknown artist" at the top row where the artist is supposed to be....
I am trying to live with it at this point, but I find something annoying, and would appreciate some help:
When I am at CD1 (Scan Playlists), I click it using the new controller, and it shows my playlists. After selecting Playlist 1, for example, it starts playing the first song in it, but doesn't go to the song list. I have to separately press and hold the Forward button (Down arrow on the right side of the steering wheel) before it will get me into the songlist.
Is this strange? How are you navigating the Dension?
Sorry for the long and confusing post, but I am somewhat lost here. Thanks in advance for any insight.
Old Feb 21, 2011 | 07:36 AM
  #474
nelson29's Avatar
My fault, i thought you had a pre-lci model. im guessing you didnt have navigation on you car before the CIC?
I didnt get your email on the Dension. It looks like im the only one that did not have a problem with mines. I sold mines a couple of months ago, im in the middle of doing the 6fl retrofit. I dont remember how the dipswitch was set, i left it the same way as when i had the M-ASK.
Old Feb 21, 2011 | 07:48 AM
  #475
merkava74's Avatar
Thanks! I will order it in then! I think mine is 51456978685, as my trims are ALU FEINSCHLIFF. No, I did not have Nav on mine.
I'm not too keen on the 6FL retrofit, as I read comparisons in terms of capacity of songs, sound quality (I use lossless) etc. Educate me if I am wrong here. Also, I would like to add video functionality to the Dension, and am currently looking to see if the Dension AVR will do the trick with some modifications.
By the way, I think I have the first E60 retrofitted with CiC in Singapore! : )
Old Feb 21, 2011 | 10:01 AM
  #476
lopealle's Avatar
I'm definitely intrested in this 6FL retrofit. Although I thught you could play Ipod through the USB on the CIC.
Old Feb 21, 2011 | 11:45 AM
  #477
bruce_miranda's Avatar
No you can't. The USB on the CIC is only used for Import/Export of CIC related data.
Old Feb 21, 2011 | 01:54 PM
  #478
roadrunner1's Avatar
Got my install done over the weekend. Things went well but for a blown fuse which caused big time delay. Also replacing the old idrive controll with the new one was a pain. I now have current CIC nav working but for voice control. Only need a programming with Patryk. Most everything working fine in a 2008 E60 535xi. A DIY to follow once the full install is complete.
Old Feb 21, 2011 | 07:25 PM
  #479
Ehssan's Avatar
My Ride: Many BMW's
Anyone has 6FL retrofit DIY ??
Old Feb 21, 2011 | 07:29 PM
  #480
nelson29's Avatar
You have to have combox installed first and from what i understand its pretty much an easy install.
