CIC install, gray 'Navigation'. Emulator issue?
My Ride: M5 Fully Loaded
Engine: S85 V10
I just did my CIC install. When I first plugged in the CIC and turned it on, navigation showed up. Then I wired it the emulator and the navigation became grayed out. Any way to test the emulator to see if it's defective?
Thx
Thx
Engine: S85 V10
I am having trouble coding the CIC though. See attached
Engine: S85 V10
I also bought the emulator on ebay. The rest of the parts came from dealer or board members.
Interestingly enough everything works now including navigation. I only have two glitches to deal with. First, I have not been able to code the CIC using NCSExpert due to the error.
Second, when I did the oil measurement is shows up as above MAX. My car is an M5 and it takes 10 quarts of oil. The donor car was a 2010 535xi which takes 7 quarts. The CIC must somehow be confusing the car regarding the amount of oil needed.
Engine: S85 V10
I did a TEST_CODIERUNG and the CIC is now in German and all M-Specific functions and Nav are gone.
After the car slept, the CIC reverted to normal. Still can't code it though. Updated the DATEN to V54. I am attaching the ncsexpert error log.
My Ride: 2010 BMW 528XI, 1954 Oldsmobile Super 88 324cui
Model Year: 2010
Can't help you beyond that but yes an Emulator is typically required for it to function as it should. I pieced mine together with various parts around eBay and works great.
Engine: S85 V10
I ask because I had a unit that had the same symptoms, someone had mashed it together using different CIC units from different cars, in an attempt to make them work. The mother board was from a `10 535 wagon from Europe, the DVD player was from an `09 M5, it was really wonky. I never got it to work, so I unloaded it for parts.
p.s. Mine works, I just can't communicate with it using ncsexpert
Model Year: 2010
I had it sent to a guy in NJ he told me by looking through some of the modules. He also was not able to communicate with ncsexpert, but I have no idea how he did it beyond that.
Try bmwcoding.com
Try bmwcoding.com
DavaiLave
08-02-2022 02:16 AM
chadillac2000
42
09-13-2017 11:15 AM
