ccc reterofit
Old 06-12-2011 | 02:59 PM
viper1213's Avatar
I know this has probably been ask before but i the threads i found were from a few years back i have an 2004 bmw 530i produced in 03/04 i believe and i wanted to do a ccc retrofit since i have a mask unit. Does anyone know if it's possible and if so what do i need to do it. Any help would be appreciated thanks.
Old 06-15-2011 | 11:12 AM
umichchris's Avatar
My Ride: ///M5 BEAST
i just bought a system too...and need more parts....not fully sure which ones or where to get them or even what the right part numbers are...
i see tons of info on the CiC retrofit, but nothing for poor bastards like myself just going the Mask to CCC route....any help for the both of us would be greatly appreciated!
Old 06-15-2011 | 11:20 AM
BLooD's Avatar
CCC retrofit check-list
CCC ?
GPS antenna ?
Controller high (haptic feed back) ?
CCC fan cable harness ?
Centre console trim cover ?
8 inch board monitor ?
Fitment is fairly easy but your car will need coding afterwards.
Old 06-15-2011 | 11:36 AM
umichchris's Avatar
CCC - check
GPS antenna - Needed....anyone have a part number for this? a member suggested i get a generic farka antennae on ebay, tons to choose from is there a specific one to buy?
Controller high (haptic feed back) - Needed(?) are you guys 100% sure i cant use my old iDrive controller for this retrofit? i dont care about having the force feedback option
CCC fan cable harness - needed - part number? i did a test install to see what was needed, much seemed to be plug & play, i dont know where this cord would go or plug into existing cables??
Centre console trim cover - definitely need this, but i dont have a part number and my ebay searches are turning up empty
8 inch board monitor - check
i looked on realoem.com to try to track down some of these part numbers but its not the most simple site to utilize.
any links on an old retrofit/install DIY from someone on the forum? any thoughts on coding before i call the stealership for a quote?
Old 06-15-2011 | 11:41 AM
BLooD's Avatar
Originally Posted by umichchris
CCC - check
Yes the controller high is need as it`s a pre-LCI car im afraid, PM me your VIN no. and trim colour/spec and ill get you the trim part no. right now.
I don`t know how you get hold of the fan cable harness, it`s not listed on the ETK (dealer parts cat.) but it`s needed thats for sure.
I have heard of ppl using an E39 antenna or you could use a third party one and fit it under the centre speaker grill.
Old 06-15-2011 | 11:50 AM
viper1213's Avatar
CCC check
GPS antenna check
Controller high (haptic feed back) need
CCC fan cable harness need
Centre console trim cover need
8 inch board monitor check
hey chris i found a website that sells gps antenna this is where im getting mine from:
http://www.uvworldwide.co.uk/gps-ant...and-p-382.html
Blood do you know if the fan cable harness is to connect the fan to the ccc? I have seen a few ccc with a fan in the back do they not need the harness then? Thanks for all your help blood it seems like not that many people are helping with this retrofit.
Old 06-15-2011 | 11:52 AM
viper1213's Avatar
a fellow member locomotivebart told me that:
You need a fan cable unless your car already has it (probably not) and you need to trim the little tit off of the video cable in your car to allow it to go in to your CCC. (has to go in backwards).
does this mean i can use my existing mask video cord for the ccc just by cutting some of the trim off?
Old 06-15-2011 | 11:53 AM
BLooD's Avatar
Yes theres a cooling fan at the back of the CCC and the M-ask has not got one as it does not need the extra cooling, you will need wire in the harness for it to work.
Old 06-15-2011 | 11:54 AM
BLooD's Avatar
Yes that is correct the cable is the same but the connector is back to front.
Old 06-15-2011 | 12:02 PM
BLooD's Avatar
Official retrofit instructions for Pro navigation option SA609.
Quick Reply: ccc reterofit
