Can I run Style 166 wheels non-staggered?
Old 08-07-2006, 10:34 AM
kchan's Avatar
My Ride: 07 BMW 525i Premium Package, Xenon Lighting Package, manual Transmission. Titanium Grey, 20% Tint around the back, 70% V-Kool on front. Planned mods: Style 71 wheels with Toyo Proxy 4 tires, Sachs suspension upgrade, upgraded stereo, and many more to come.
Hi all,
Thinking about the style 166 wheels, but wonder if anyone has put them on without the stagger setup, meaning 245/35/19 all around. I think stagger definitely looks nicer, but then:
1. it weighs more
2. if the setup is the same I can rotate them around
3. tires will be cheaper and in case a tire blows or run flat i have more choices of what to do
4. more choices on tires
To me 245 seems plenty wide, and I really prefer not to add extra weight on the wheel setup since I have a 525i to begin with...
Besides a nicer look (and a slightly better traction with 275 or 285 on the back), what will I be missing by going non-staggered? Is there any other issues that I wasn't thinking of that makes going non-stagger a bad idea?
Thanks!
Old 08-07-2006, 11:07 AM
vegastrashed's Avatar
Originally Posted by kchan' post='319861' date='Aug 7 2006, 11:34 AM
Hi all,
1. it weighs more
Thanks!
I don't think the rear wheel (9.5X19) can accommodate 245s. 245s barely fits the front wheel (8.5x19). If you want to use 245s all around you can go with replica 166s.
Old 08-07-2006, 11:15 AM
BMW#7's Avatar
Don't see any reason why the 245's wouldn't fit at the rear.
The one problem with putting 245's at the rear may be with the offset. You may need to add spacers to correct the problem.
Old 08-07-2006, 11:36 AM
kchan's Avatar
Can I use the OEM 166 front wheels on the back also, meaning get 4 identical front OEM wheels?
I believe the offset of the stagger setup is so that the rear has a higher offset to accomodate the wider tires on the back?
So if I use an 8.5" wide wheel with the 245 tire on the back, should it 'sticks out' the same as the 9.5" wide with 275? The width will be different but the outer wheel surface should be the same for both setup?
The front offset is 12, rear offset is 28 (for 9.5" wheel), so difference is 16, which is roughly half of the added width going from 245 to 275?
Sorry so confuse....
TroyE60
05-30-2019 05:01 PM
The_Sauce
06-26-2015 07:40 PM
lowcg3
04-11-2015 02:57 PM
bestofthebest
03-30-2015 08:12 PM
06-17-2003 09:38 PM
Quick Reply: Can I run Style 166 wheels non-staggered?
