Can I replace door bulb from 5W by 10W
Old 03-05-2018, 03:10 AM
kenza750's Avatar
My Ride: E61 525dA, High Executive, Xenon (AHL), leather+memory, CCC Prof, pano-roof
Engine: M57 (256D2)
Default Can I replace door bulb from 5W by 10W
Hi all,
As far as I know the bulbs in the doors (under) are 5W type. I would like to have a more intens light when opening the door. Can I replace the stock 5W by 10W of does this trigger an error?
I like the yellowish color, that's why I do not want to switch over to LED.
Old 03-05-2018, 08:42 AM
FormerE30Owner's Avatar
My Ride: 2005 545i, premium package, 6sp manual, cold package, navigation package.
Model Year: 2005
Engine: N62
I think that those are T10 bulbs. Try the 10w and see. You will pull more amps, but shouldn't blow a fuse.
Old 03-06-2018, 12:17 AM
kenza750's Avatar
Engine: M57 (256D2)
Thnx for your reply. I will try a 10W bulb first, but I wonder whether this will not introduce too much termal issues (overheating, melting of plastic).
I have also seen there are LEDs available which gives "warm white" color (T10 LED). Maybe I will try this also. There are a lot of different SMD-LED with various output brightness.
I will update this post as soon I've tried some alternatives.
Old 03-06-2018, 12:26 AM
Model Year: 2005
Engine: N62
[COLOR="Blue"]Aren't those door lights on only when the door is open? In that case, those door lights (under) aren't on long enough to cause overheating.
The LEDs will not cause heating problems, but might trigger warning indicators.COLOR]
Last edited by FormerE30Owner; 03-06-2018 at 12:28 AM. Reason: sentence construction!
Old 03-06-2018, 03:22 AM
kenza750's Avatar
Engine: M57 (256D2)
I will try today removing one bulb to see if it throws an error. Maybe there is no CAN-bus check on these lights...
bip78
13
11-07-2011 11:47 PM
Burj530
09-13-2008 09:13 AM
POGI
DIY: Do It Yourself
02-12-2007 01:02 PM
kreate2
12-25-2005 12:43 PM
Merv the Derv
04-25-2005 09:20 AM
Quick Reply: Can I replace door bulb from 5W by 10W
