Caliper guide pin bolts
My Ride: '06 550i
'84 Nissan S12 Turbo
For the people that have changed out your brake pads.....did you lube the guide pin bolts? If so what did you use?
The "how 2" I read said to just clean the guide pin bolts, and not to lube, which I find weird. I've always greased guide pin bolts on other cars, why not on these cars?
I used coastal Moly grease found at autozone, not too pricey. pictured in this link https://5series.net/forums/topic/102...1#entry1222231
Clean them off and give them a pinkys worth of grease. I also lube or antiseize the areas where the pads slide in the carrier and where they press into(piston area)
My Ride: '06 550i
Check it out here..... https://5series.net/forums/index.php...attach_id=7262
Page 2, it says under INSTALLATION: "Only clean guide screws; do not grease."
Can anyone explain why it says this?
Wonky
04-12-2016 08:15 PM
spediegunz
08-30-2015 09:43 AM
