Buying used headlight assy, for a 2004 525i
Old Jan 19, 2011 | 03:44 PM
oc2vgs's Avatar
I have a 2004 525i. I need to replace both front headlights. The right headlight projector gets stuck at times facing the sidewalk. I have adaptive headlights that use D2S bulbs. I fould a used set of heaflights from a 2007 530i, but I know the 2007 pre-lci used D1S buls. Will this headlights work on my 2004 since mine are D1S bulbs.
Old Jan 20, 2011 | 12:57 AM
orlovskyy's Avatar
y don't u just retrofit to lci heads? they look so much better and ur gonna be paying nearly as much for pre lci xenons anyways
Old Jan 20, 2011 | 03:49 AM
medik13's Avatar
It should be a direct swap. Your harness should accept the newer D1S ballast and bulbs!
Old Jan 22, 2011 | 02:31 AM
jas_r_1's Avatar
My Ride: 2006 520d - 19" 172s- Remapped - LCI taillights V6 cables - LCI xenon headlights - Denison 500 with BTA1500 - led interior lights - OEM led number plate lights Planned mods: Folding mirrors - Modmynav kit - High gloss shadowline trim -
Let us know if this works as i have a set of used xenon headlights which take D1S bulbs. I am planning on selling them so it will open up the options if older cars can take them as well.
Old Jan 23, 2011 | 09:14 PM
balbs's Avatar
My Ride: BMW
I thought you also need the new light control module + programming if you want to change to LCI w\adaptive xenons from Pre-lci???
TexaZ3
May 6, 2015 09:54 AM
BYS2
Mar 24, 2015 03:13 AM
Brooklyn88
Mar 21, 2015 06:23 PM
BMW_DepDe
Mar 17, 2015 02:47 PM
