BMW OEM Plate Light LED's
#61
My Ride: 2007 E60 530i
Color: Jet Black/Black Anthracite
STEP | Sport | Premium | NAV | Logic 7
EXTERIOR:
M-Tech Kit | M5 Mirrors, Trunk Finisher | Jet Black Kidney Surrounds | Madico Charcool Tint 54%, 35%
LIGHTING:
Euro-Headlights | Euro-LCI Tail Lights | AiB V3.0 | Solaris Invisi-bulbs | OEM LED Plate Lights
PERFORMANCE:
Porterfield R4-S Brake Pads | K&N Air Filter
WHEELS & SUSPENSION:
Work VS-XX 20x9, 20x10 | Toyo T1R 245/30/20, Michelin Pilot Sport A/S 295/25/20 | KW V2 Coilovers | Rogue Engineering 15mm Spacers
You need to order all the hand written part numbers. There are 4 wires (2 red, 2 black) and two connectors. Also order the first printed part number which are the lamps. Just call Garry, he'll take care of you.
#62
My Ride: E60 530i
Engine: M54
Thanks,
#64
EXTERIOR:
LIGHTING:
PERFORMANCE:
Give Garry a call, he'll set you up with the right parts.
#65
#66
EXTERIOR:
LIGHTING:
PERFORMANCE:
These LED's come stock on the 2008 E9x. Just call the parts department at your local dealer and they should be able to give you the right part #'s. You can always e-mail Garry to confirm what the correct part #'s are.
Fred or Mike? Do you guys know the right part #'s?
#67
Did anyone on the e90 forums ever come out with a simple plug and play solution? mine are still sitting in a box. Been too lazy to try anything. haha, and its getting cold out here.
#68
EXTERIOR:
LIGHTING:
PERFORMANCE:
I've been using my resistor setup for over a month now and haven't had any issues with them. Spend some extra money on the heatsinked ones for peace of mind and you should be good to go.
#69
Guys,
I installed my OEM LEDs with the following Radio Shack resistors, on the positive and negative side. I'm not experiencing any IDrive Error or strobing on the OFF position of the Light switch.
Resistors- 50 ohm, 10 watt, 10% tolerance (Cat No. 271-133) 2 ea.
