bmw e61 FLA retrofit
My Ride: BMW 530d
Hello! I have retrofitted the rear view mirror with FLA, connected it and it shows in INPA. Then i added $5AC VO to both CAS and LMA. After that CAS, LMA, RLS, FLA, KOMBI ecu's were reset to factory settings, however the high beam assistant icon is not showing up in instrument cluster and it does not work. Am i missing something or what could be the issue?
My Ride: 05 530i M54
Model Year: 05 530i
Engine: 3.0 M54
My Ride: BMW 530d
maybe i am doing factory defaults wrong? I am using expertmode profile, without man manipulation, choosing each module and doing SG_CODIEREN. Does it really resets modules to defaults? Because i have coded american look and after LMA reset it still remains enabled.
Model Year: 05 530i
Engine: 3.0 M54
Factory default steps. Ensure .man file is empty or turn of manipulation. It will code module from VO
1. Load NCSExpert.
2. Load Profile and select Expertmode
3. F1 (VIN/ZCS/FA)
4. F3 (ZCS/FA f .ECU)
5. Choose E60
6. Select Module
7. F6 (BACK)
8. F4 (Process ECU)
9. Select the Module I want to Revert back to Stock.
10. F2->Choose "SG_Codieren->ok
11. F3->to start coding the ecu with factory settings according to the vehicle VO.
1. Load NCSExpert.
3. F1 (VIN/ZCS/FA)
5. Choose E60
6. Select Module
7. F6 (BACK)
8. F4 (Process ECU)
My Ride: BMW 530d
1. Load NCSExpert.
3. F1 (VIN/ZCS/FA)
5. Choose E60
6. Select Module
7. F6 (BACK)
8. F4 (Process ECU)
1. Load NCSExpert.
3. F1 (VIN/ZCS/FA)
5. Choose E60
6. Select Module
7. F6 (BACK)
8. F4 (Process ECU)
