bluetooth retrofit ncs coding help
Hello all I have successfully performed a tcu retrofit on my 04 with CCC and now have my phone paired up with bt working on my car problem is I can't control any call functions from the car or steering wheel button. In commucations it says i have no phone installed.
In ncs so far i have done the following
added +k633 ,$639 and $605 to the VO
Read out the trace from the TCU module and set :-
BT_ENABLE aktive
USED_MICROPHONES wert_01
Read the trace for CAPPL (ccc_app) and set:-
BLUETOOTH_NODES_CCC profile_2
TELEFON_TYPE_C08
PHONE_VERSION most-phone1-1mic
Read the trace for CCC_ASK (ccc-audio) and set:-
I tried to see if i can turn off PHONE_BUSINESS, and PHONE_PROF because they might be possibly interfereing with the bt phone but when I read the cappl ecu those parameters are not listed?????(note. I have the latest daten files)
Any help any ideas on what should i do???
BT_ENABLE aktive
TELEFON_TYPE_C08
Stormcrow
12-01-2019 02:09 AM
rackhacker9275
26
04-16-2015 08:13 AM
rizwan1377
04-05-2015 05:22 PM
