better aux?
thinking off installing an aux input when i saw this ad on ebay.
http://cgi.ebay.com/ebaymotors/ws/eB...ategory=171098
Do you think i should gowith this or stick with the factory aux input?
My Ride: BMW E60
Model Year: 2016
Derr, I would request real pictures of the product. I am not sure how the person can claim it's plug and play if it's not a female input. That means you will have to get another female adapter to actually input anything. In addition, wth is that picture of the wire created in MSPaint? Wtf?!
Well i asked for a pic. He said I'm sorry I do not have a picture. It is a 3.5mm cable with female connectors on the end for you to plug into your existing BMW Xplug. Installation instructions long with the schematics of which ports to use etc.
So i guess i should get the factory one?
My Ride: check siggg
i have personally done the install for AUX cable on a e46 m3 and i can tell you its not that simple. like nguyenazn stated, you have to remove the trim then remove the center concole and drill a hole somewhere to route the cable out. the lci e60s have this style input. http://www.e90post.com/forums/attach...hmentid=485910 it is a usb as well as AUX combined into this cable http://www.mini2.com/forum/attachmen...8&d=1188897814 IIRC the BEST for pre lci, and what i would reccomend is the dension gateway 500 which allows for the integration of whatever your attempting to play thru the idrive
bestofthebest
03-28-2016 02:47 PM
