AUX IN retrofit problem
I bought a retrofit kit and have installed the cable following the instructions including recoding the MASK with NCSExpert.
The AUX IN option is on the screen and I'd plug in my external device but no sound is coming out.
I pulled everything apart again to double check nothing is loose but still no luck.
Does anyone have any clue whats wrong?
My Ride: 545 modded the F out
damn. Thats weird. My first guess was that the coding hadn't taken place. Since you said that it was indeed done and you already troubleshooted the entire thing I say get the coding done again. Or you just have a fault wire.
if the hardware looks to be intact then you know for sure its software. Sorry cant help much more than that. GL tho
rizwan1377
04-05-2015 05:22 PM
