AUX IN questions
Old Feb 19, 2008 | 04:43 AM
Centaurus's Avatar
My Ride: 520i M54 Manual, Saphire Black Metallic, Purchased 03/2004 Standard Equipment: Bi-Xenon Adaptive Headlights, PDC, Airbags all Around, Folding Mirrors, Active Steering, Extended Lights Package, Aluminium/Black Interior, Heated Black Dakota Leather Comfort Seats, Folding Rear Seats w/Ski Bag, Logic7Audio, Car Key Memory. Retrofitted: ///M Tech Aero Kit, ///M Tech Wing Mirrors, ///M5-Forged Wheels, G-Power Quad Exhaust.
Hi,
i want to retrofit the AUX connection myself.
My Bimmer is a 2004 without navi and CD-changer.
On the original AUX retrofit equipment is the plug X13813 mounted, but i unwilling to do retrofit with the org. AUX adapter because i don?t need the resistor/ capacitor.
My question: is there already the X13813-plug on the on the CCC/MASK?
Has anybody a AUX installation manual with pic?s (not for the org. AUX equipment)
Thanks in advance !!!!
(sorry English isn?t my native language :-)
Old Feb 19, 2008 | 04:57 AM
nicke60gre's Avatar
Originally Posted by Centaurus' post='533066' date='Feb 19 2008, 03:43 PM
Hi,
X13813 will be there, only if your car is equipped with bluetooth or Nav pro (this is the plug that is used as input for nav voice commands microphone, bluetooth hands free microphone and aux-input.
Old Feb 19, 2008 | 05:35 AM
Centaurus's Avatar
many thanks !!
Old Feb 19, 2008 | 10:00 AM
vesil's Avatar
My Ride: F11 520d
Did I get this right:
If I have a car with X13813, there is no reason to buy original AUX-IN retrofit kit?? I just need coding at dealer.
According wiring diagram the cable is really simple. If I make cable myself, I can locate 3,5mm plug wherever I want.
Old Feb 19, 2008 | 11:16 AM
bruce_miranda's Avatar
The only thing to buy would be the 3 tyco pins at the end to go into the X13813
Old Feb 19, 2008 | 11:53 AM
Centaurus's Avatar
yes it isn?t necessary to buy the BMW cable because you don?t need the resistor/ capacitor.
You only need the pawl plug, cable and the X13813 plug!
Old Feb 19, 2008 | 12:57 PM
Infact you dont need the X13813 plug either. Your 3 tyco pins will go into the already existing X13813 plug. It's been done before http://forums.e60.net/index.php?showtopic=...st&p=186576
Only because that in saving a few pennies you dont go and destroy the trim pieces while trying to get to the back of the CCC.
Old Feb 19, 2008 | 01:11 PM
nicke60gre's Avatar
Here is the X13813 plug with the pin contacts you need (if you have OEM CD changer you may already have it)
http://cgi.ebay.de/Quadlock-Most-STECKER-A-Kammer-Line-IN-AUX-Telefon-CD_W0QQitemZ270211214714QQihZ017QQcategoryZ27450QQssPageNameZWDVWQQrdZ1QQcmdZViewItem
and here is the official retrofit instructions
Aux_in_retrofit.pdf
Old Feb 19, 2008 | 03:25 PM
radioham's Avatar
My Ride: 640D MSPORT GT
read all the posts on retrofit aux in.before you start.
the car will require coding to enable aux in menu by dealer. X13813
the cable supplied carries all wiring and the plug connected you have to remove the pins and replace in original plug xi13813 pay particular attention to pin nos. even dealers mix them up.
MAKE SURE YOU HAVE CAR IN DRIVE POSITION WITH GEAR SELECTOR BEFORE you disconnect battery. as you wont be able to remove ccc.(slides out in direction of gear selector.
ALSO check on active steering lock if applicable to your car.
its all on here in search.
Old Feb 19, 2008 | 10:27 PM
vesil's Avatar
My Ride: F11 520d
Thanks for all comments! They confirmed my suspections.
Even though I spend a good while with search, I did not found thread " infamious "aux" imput?, radio location?". Thanks for link Centaurus!
predshaw
13
Nov 22, 2021 05:58 AM
zukgod1
Jul 14, 2015 10:19 PM
Bank$hot530
Jul 12, 2015 04:36 PM
w84me
Jul 10, 2015 10:56 AM
ST JAMES
Jul 3, 2015 07:04 PM
