Attempted to do a M5 mirror install today but ran into a problem
Old 04-06-2009, 10:02 AM
bruce_miranda's Avatar
I needed to swap my Hi-Fi tweeters and wanted to perform the extended lights retrofit into the doors so I thought I'd do my M5 mirror retrofit as well but ran into a problem. The WDS does not seem to be much help so I'm wondering if anyone else can help.
I have a Jan 2006 car which I thought was meant to have the 3 wire in a single plug mirror interface but I actually have 4 wires in a single plug. Does anyone know what going on here? The M5 mirrors I have are the post Sept 05 mirrors with 3 wires at the end. So how is this supposed to be plug and play?
Old 04-06-2009, 10:08 AM
nigxdoof's Avatar
Any pics of the harness?
I have Pre 09/2005 but I can try to help. =) Its possible its an extra option on those mirrors.
Old 04-06-2009, 10:25 AM
I can provide a picture but this is probably better.
The mirrors have 4 wires going into a 4 terminal plug.
The mirror wires are
Pin 1 - White
Pin 2 - Red
Pin 3 - Brown
Pin 4 - Green
This plug mates with a socket housing in the door, the wires to that are
Pin 1 - Blue/Yellow
Pin 2 - Yellow/Blue
Pin 3 - Brown/White
Pin 4 - White/Blue
Its the same on both sides.
Old 04-06-2009, 10:54 AM
mikeg3tsguap's Avatar
Interesting maybe they gave you wrong mirrors
Old 04-06-2009, 10:59 AM
Its the extra "White" wire on the original mirror that is confusing me. The others are all the same colours. The WDS is completely useless in this area.
Besides ripping open the original mirror to look inside anyone else run into this issue?
Old 04-06-2009, 12:43 PM
Gudge's Avatar
Where is the extra white wire going into on the mirror side? I had the 3 plug version, but it should be possible to see if the wires are going into the EC Glass, or the puddle lamp, or to the main mirror housing itself.
My advice would be to plug it in and see if it works.....(worked for me)......But I guess that's not really the answer you are looking for.
Old 04-06-2009, 12:57 PM
I didn't want to rip the old mirror apart to see where the white wire was going. But maybe I have to now. Problem is that if the car has four wires then I'll be looking 'something' if I plug a mirror with 3 wires into it.
The funny thing is my original mirror is absolutely basic. It only has the heated glass and the mirror motor ofcourse - so why does it need 4 wires. The M5 mirror on the other hand is fully loaded and uses only 3 wires. I can understand the 3 wire configuration i.e. Ground, +12V and the LIN Bus.
Old 04-06-2009, 01:04 PM
OK I think I found it (and I'm probably colour blind as well - or maybe it was just too late and the light was low).
The WDS is wrong but I think my car is a 3rd variant that people have never mentioned here.
Its a car that has the Body Gateway Module but doesn't use the LIN bus for the mirrors.
See picture.
Looks like I'm going to have some M5 mirrors for sale soon! Thank goodness I didn't paint them.
My previous post should have looked like
Pin 1 - Green
Pin 2 - Brown
Pin 3 - Red
Pin 4 - White
Pin 1 - White/Blue
Pin 2 - Brown/Yellow
Pin 3 - Yellow/Green
Pin 4 - Blue/Yellow
Attached Thumbnails Attempted to do a M5 mirror install today but ran into a problem-m5mirrornolin.jpg
Old 04-06-2009, 01:10 PM
Gudge's Avatar
See picture.
Pin 1 - Green
Pin 2 - Brown
Pin 3 - Red
Pin 4 - White
Pin 1 - White/Blue
Pin 4 - Blue/Yellow
That's interesting Bruce - but what does it mean in laymans terms for the uninitiated among us ? Why are these mirrors no good to you ?
Old 04-06-2009, 01:14 PM
AKAlius's Avatar
hey Bruce, is it still possible that you can still use the mirrors for your car? Maybe hacking the harness a bit to make it work?
Quick Reply: Attempted to do a M5 mirror install today but ran into a problem
