Aftermarket trunk sub, turns off above half volume
My Ride: Base model E60 with a sub and rear seat swap for folding seats
I have a 2009 528xi, I just did a trunk sub set up. Is there a high voltage cut out for factory amp. I did the standard ”Tap and play” where I tapped into the factory subs and remote wire.
The issue is and high volume the sub doesn’t stay on it shuts off at about half volume.
Anyone know how to fix it?
Fixed
Sorry forgot to update it, I figured out that I had a 4 ohm amp, and the wires I tapped are 2 ohm. So if anyone else is going to put in a trunk sub and you tap factory signal wire to run a rca adapter, make sure you have a 2 ohm amp!
the input side of the amp has nothing to do with the Ohm rating of the amp… a 4ohm amp only means that it can’t handle being wired to 2 ohms or less at the speaker output… a 2 ohm amp can be wired to 4 ohms or two ohms once again, having nothing to do with the input stage
If you’re using the speaker wires, you just need to make sure you use a good Line output converter and make a solid connection when you tap in or use an amp that has speaker level (or high-level) inputs… I personally used the low-level wires in the amp harness which allowed me to run RCAs direct from those wires w/o needing the converter
don’t get me wrong… I’m super glad you got it worked out… just making sure you have the right info going forward (ex sound quality competitor and magazine editor)
E60Rules
DIY: Do It Yourself
52
02-04-2024 09:41 AM
nice_camel_toe
19
05-07-2007 10:09 AM
