Advice on Pre LCI Xenon to LCI Xenon
#71
My Ride: BMW E60
Model Year: 2016
nomis,
Forgive my ignorance on this. I did some more research in the forums and have come to realize that you are also very adept at programming etc when it comes to our cars. Having said that, I now have more insight on why you might ask this question. Have you had experience in re-coding the LCM and AHL modules and was their a problem with this from your perspective?
Thanks for the input!
That is why I was wondering if there's a confirmation about this.
KingKashi (02-08-2020)
#72
My Ride: 2007 Black Sapphire 535i
The reason I ask is because there seems to be conflicting answers regarding this. A respected member that has done the conversion before me recommended buying new, but I was thinking about it logically, and I would think an used set would work just fine.
With Patryk's help I should be able to confirm or dispute the functionality of our old AHL modules, re-programmed with the new LCI Lamps. I haven't bought any for my install so I'm hoping for the best also. I'll keep you posted.
#74
Well it took some doing and some shrewd negotiations on eBay but I was able to buy the RT light fixture NEW (Hella OEM) for USD $350.00 and the LT light fixture USED but no broken tabs and a very clean lens (Hella OEM) for USD $225.00. Both have the servo motors for AHL but no Xenon bulbs, ballasts or AHL modules (Fairly standard for most headlights found on eBay for the E60). They came from different sellers. So @ $575.00 for the pair, I did fairly well.
Hopefully I can finally put this one to bed in a few weeks.
#78
Simon or any others in the know, help!
I did the LCI conversion on my car today with Headlights and Tail Lights and it seems that something is going wrong with the coding portion. Here's what I've done...
- I've added a newer date-code to my VO so that NCSExpert shows the LMA module. (I installed the new module today as I have a pre 0709 production E60). For reference the module shows up as LMA, not LMA2 or LM2. Is this correct?
- I also added +MUEB to my VO
- I coded the LMA with an empty *.MAN file to ensure that I started the module with a clean flash. Front Headlights work flawlessly. I even made some coding changes like disabling the Eyebrows etc which all worked. I even re-coded the CAS with a clean flash for good measure.
The problem is I am getting the following errors in iDrive although the rear Tail lights appear to be working just fine. Driving lights work and brake lights work).
Right tail lamp malfunction
Left tail lamp malfunction
Right brake lamp malfunction
Left brake lamp malfunction
I'm pretty sure my wiring is solid but experience tells me I should not rule anything out. I'm been in the garage all day with this...Arrgghh!!!
#80
Did you rearrange the pins on the taillight harness? Some of them are not correct.
