Hello guys I'm trying to install a TCU module on my 5 series 2005 E60 it doesn't come installed from factory but there is the wires just to plug and play, but I have a big problem because does not appear on inpa ¿What I need to do?
NOTE: Using NCS Expert I added some VO $639 and $612 HELP! ))
I updated your post to what you wrote on FB so it is in English. If the solution given there doesn't work out then let me know. This is nothing but a simple program and code job.
If the vehicle is pre-wired but does not have a module factory(on the Most loop) then you will have to change the routing on the most block so that all connected pieces get the feed.
Basically if the green fiber optic feed isn't lit up when its unplugged then its not getting the source and isn't connected
