About OEM M5 BBK Installation - Hubs Modification
My Ride: 2004 545i Custom Matt White Paint by PLATINUM VIP | Sport Pkg | Cold Weather Pkg | 6 Speed Manual | Premium Sound | Oem ///M5 Front Bumper | Oem ///M5 Rear Bumper | OEM ///M5 Side Skirts | Oem ///M5 Trunk Finisher | Oem ///M5 Fenders | 20% Tint | Vip Modular Wheels | 21x9.5 F | 21 x11 R | Magnaflow Exhaust | AAA Oval Tips | RPI Scoops | KW V2 Coilovers | Predator Ice V2 Angel Eyes | LED Side Turn Signal Markers ( Smoked ) Cross Drilled Rotors | CF Engine cover | Axxis Deluxe Break Pads | K&N Drop in
My Ride: 545i Sport
Engine: N62
I started the rear M5 brake install but gave up.
![About OEM M5 BBK Installation - Hubs Modification-help.jpg](https://5series.net/forums/attachments/e60-e61-parts-accessories-mods-22/83437d1482364887t-about-oem-m5-bbk-installation-hubs-modification-help.jpg)
The parking brake upper spring is kicking my butt. Is there a special tool to make reinstall easier?
I'll continue tomorrow after getting the tool from Pepboys. DIY in work.
![About OEM M5 BBK Installation - Hubs Modification-help2.jpg](https://5series.net/forums/attachments/e60-e61-parts-accessories-mods-22/83438d1482364887t-about-oem-m5-bbk-installation-hubs-modification-help2.jpg)
New rotor teaser pic.
![About OEM M5 BBK Installation - Hubs Modification-help3.jpg](https://5series.net/forums/attachments/e60-e61-parts-accessories-mods-22/83439d1482364887t-about-oem-m5-bbk-installation-hubs-modification-help3.jpg)
New M5 rear Protector plate installed. Thanks for the install tip andy545
I see (from the scratches) you are left-handed hahaha
just slide it behind, catch the one hole and then with a long thin screwdriver from below against the inner hub, drag it until it come in front of the hole. Then just push it with something to slide it in, at the same time pull the screwdriver out
Originally Posted by nicke60gre' post='930347' date='Jul 2 2009, 04:20 AM
I see you are left-handed hahaha
just slide it behind, catch the one hole and then with a long thin screwdriver from below against the inner hub and drag until it come in front of the hole. Then just push it with something to slide it in and at the same time pull the screwdriver out
![Worthy](https://5series.net/forums/images/smilies/imported/worthy.gif)
My Ride: 545i Sport
Engine: N62
![About OEM M5 BBK Installation - Hubs Modification-step9.jpg](https://5series.net/forums/attachments/e60-e61-parts-accessories-mods-22/83484d1482364887t-about-oem-m5-bbk-installation-hubs-modification-step9.jpg)
9. Assemble shoes, lower spring(easier, less tension) and adjusting screw.
![About OEM M5 BBK Installation - Hubs Modification-step10.jpg](https://5series.net/forums/attachments/e60-e61-parts-accessories-mods-22/83485d1482364887t-about-oem-m5-bbk-installation-hubs-modification-step10.jpg)
10. Install shoes by inserting the spring loaded pins and rotating them 1/4 turn. The pins go through a hole in the shoe
and then through a slot in the backing plate. If you use a flashlight from behind, it's easier to line up the pins properly .
![About OEM M5 BBK Installation - Hubs Modification-step11.jpg](https://5series.net/forums/attachments/e60-e61-parts-accessories-mods-22/83486d1482364887t-about-oem-m5-bbk-installation-hubs-modification-step11.jpg)
11. Replace top spring.
