6HP19 L1-L4 board replacement
Old May 23, 2025 | 02:31 PM
Kturner's Avatar
Default 6HP19 L1-L4 board replacement
I have a 2004 E60 (6HP19) showing fault code 5088 (L1-L4 switch). I have a board to solder in to hopefully correct this issue. Anyone out there done this? If so, any tips? As far as I can see, carefully use dremel to remove existing potting material, clean the area, remove the old board, set and solder the new board and reseal with new potting material. Any input would be appreciated. I read in another thread that refurbished TCM's can be ordered through ZF as an option. Has anyone done this? If so, maybe you can post the ZF site that I can visit?
Thanks in advance!
Kevin
Samiamz
Jan 1, 2025 09:19 PM
rsewell
Sep 17, 2023 09:01 PM
MD-11 Driver
DIY: Do It Yourself
Apr 27, 2013 07:18 AM
mdot
DIY: Do It Yourself
14
Aug 17, 2010 10:30 AM
v_therussian
Dec 19, 2009 11:41 AM
