6 speed "lock" valve upgrade worth it?
Old Mar 14, 2008 | 04:55 PM
sirch's Avatar
My Ride: 2004 545i, BMW Stainless Steel Pedals, #166 Rims
Just got the Bavarian Autosport catalog and noticed that they sell a "unlock" valve to increase the engagement of the clutch. Is this a worth wild upgrade? Anyone tried it yet and have any feedback would be appreciated. Thanks.
Old Mar 14, 2008 | 06:18 PM
mrfva's Avatar
My Ride: .
Model Year: .
Is this the same thing as the replacement of the clutch delay valve?
Old Mar 15, 2008 | 06:25 AM
my530i's Avatar
What happens if transmission failed on the road and car was towed to dealer for checking out the transmission and found this valve?
Old Mar 15, 2008 | 09:12 AM
JPJ's Avatar
JPJ
Search on CDV you will find quite a bit.
I haven't done this mod since I have gotten used to the delay over time and also will start teaching my 14 year old son to drive soon. However, I know the general feeling is that getting one from Zeckhausen Racing is a better choice than Bav Auto. Zeckhausen is a modified factory valve vs. the generic one from Bav.
Helps address my530i's concern a little also since it looks stock on the outside.
Old Mar 15, 2008 | 01:49 PM
pa550's Avatar
My Ride: 2013 M5 - Sakhir Orange / Black Leather.
Definitely worth it. Go with the Zeckhausen version. I first tried the Bav Auto and (i) externally it looks different than the stock valve and (ii) it didn't seem to cure the delay. I subsequently swapped the Bav Auto version for Zeckhausen's and it worked much better. Zeckhausen starts with a stock valve and hollows it out. So, upon external inspection it is impossible to see that it has been replaced.
Funny, I was at the dealer in the fall and they were putting the third clutch in a 550 under warrantly . They finally figured out that the stock clutch delay valve was malfunctining, and not allowing the clutch to fully engage.
Bottom line - relatively easy mod (suggest doing it on a lift although I did mine on ramps) and noticeable.
P.S. - drop a Sprint Booster in and it'll become a different car.
Old Mar 16, 2008 | 10:10 AM
sirch's Avatar
Thanks for the advice. I think it's time to order the Zeckhausen's.
socale39
Sep 5, 2023 08:30 AM
michaelz
May 19, 2015 01:40 PM
Glowin
Apr 13, 2015 02:42 PM
OhDammm
Mar 9, 2015 10:28 AM
