530xi ride height
Has anyone verified whether the 530xi is higher (off the ground) that the standard 530i? If so, would it cause problems when upgrading the tires to go with a with a larger aspect ratio tire in order to fill out the wheel well? For example, a 245/45-18, or 235/45-18, instead of the 245/40-18. I realize this may affect the speedometer reading, but my experience with BMW speedometers is that they all read 2 to 5 percent fast. The larger tire may correct this problem. Has anyone had experience with either of these tire sizes on a 545i?
I've got a 530xiT on order and I'm upgrading the tires and wheels. Thanks for any advice or suggestions.
Originally Posted by rhnorb' date='Sep 22 2005, 11:12 AM
Has anyone verified whether the 530xi? is higher (off the ground) that the standard 530i?? If so, would it cause problems when upgrading the tires to go with a with a larger aspect ratio tire in order to fill out the wheel well?? For example, a 245/45-18, or 235/45-18, instead of the 245/40-18.? I realize this may affect the speedometer reading, but my experience with BMW speedometers is that they all read 2 to 5 percent fast.? The larger tire may correct this problem.? Has anyone had experience with either of these tire sizes on a 545i?
I've got a 530xiT on order and I'm upgrading the tires and wheels.? Thanks for any advice or suggestions.
[snapback]173636[/snapback]
The German engineers have an idea why the tires are the size they are. All the iDrive and other intelligence on the car is based on sertain mesures.
A speedometer, have to by law, show measures not higher the real values.
Go for 18" wheels if you like but do not change to wheels that are not recommended, for safe and pleasure driving.
I would not change the cars original tire aspect ratio!
Thanks for your response...I think you are probably right in advising not to change the aspect ratio. No one else has suggested otherwise.
[snapback]174494[/snapback]
[/quote]Thanks for your response...I think you are probably right in advising not to change the aspect ratio. No one else has suggested otherwise.
bestofthebest
03-28-2016 02:47 PM
