2008 E60 535i - Need to tap into fuse for radar, which to use?
Hi guys,
Coming from an E90 where I tap into the homelink fuse to hardwire my Passport radar. Can anyone tell me which fuse I should tap into for the E60? The fuse "cheat sheet" is "encrypted" and I have no idea how to decrypt what those symbols means. I looked through the manuals and nothing helps me decrypt the symbols. Help help!!!!
Thanks!!!
Thanks!!!
My Ride: 2007 525i Premium Package "All Black Everything"
EXT: 20% Tint All Round | M-Front (Weezy) | Black/White Roundels | Shadowline Paint Match Grilles | M Style Sidemarkers | Vertini Riviera-S 20s
INT: I POD Intg | Trim Rings | ACS Pedals | Cobra XRS 10G
LHT: Xenon Adaptive | XENESIS Fogs| WeissLicht Plate LEDS | Door LEDS I Interior Xenon Pkg
PER: RPI Induction (Weezy) | BMC Filter | Sprint Booster V2
AUD: JL Audio
for the glovebox fuse panel fuses 23, 43, and 44 are radio power fuses that are 7.5, 5 and 5 amperes respectively which you could use for your 12v constant. However while that might answer ur question those fuses may not "sleep" (which means the radar will still drain power) when the car is off i think the only ones that do are in the rear. you may want to look at this.
Radar fuse power down issue
chadillac2000
42
Sep 13, 2017 11:15 AM
S4CH
May 4, 2015 09:37 AM
