166M wheels with biggest tires possible
My Ride: 2007 E63 AMG | Obsidian Black | Schwarzes Nappa | Black BirdEye Maple | Premium II Package | Electronic Trunk Closer | Parktronic
Engine: RPi/Powerchips custom ECU tune, RPi Ram Air Kit (BMC filter, scoops), RennTech Sport exhaust, secondary cats, charcoal and resonator delete, custom AAA x-pipe
Exterior: 50% side windows / 35% rear window Formula One Pinnacle Series | Flat AMG hood emblem
Suspension: Renntech Lowering Module
Wheels/Tires: Radenergie R10, Falken FK452 245/30/20, Yokohama ADVAN Sport 285/25/20
2005 545i Sport SMG | Ti Grau | Schwarzes Dakota | Anthracite Maple | Logic 7 | Nav
Engine: Custom AFE CAI, Superchips ECU remap, Sprint Booster, RDSport Dual Exhaust Conversion with Quad Pipes and X-pipe, 3 resonators deleted, 90mm tips!
Exterior: M-Tech Aero kit | M5 Mirrors | M5 Rear Bumper | Trunk Lid Finisher | Vorsteiner decklid spoiler | 50% Formula One Pinnacle Tint
Suspension and Brakes: Bilstein PSS9 coilovers, JBT BBK: 16" cross-drilled rotors, 8 piston and 15" cross-drilled rotors, 4 piston
Wheels: VIP Modular VR 02 20x9F, 20x10R | Toyo T1R 245/30/20F, 285/25/20R
Lights: PIAA 4150K Xtreme White Plus fog lights, AIB v3
MOST IMPORTANT: Hardwired V1; =)
ED Date: 4/7/05, Re-delivery date: 5/21/05
Originally Posted by Blackonblackonblack' post='281796' date='May 13 2006, 12:48 AM
I just have to ask, what will you do with the 400lbs of salt! Anyway your car looks great! Too bad the 166 style doesn't come in the standard size as I was just given a free set of run-flats by the dealer...2 years and 16,000miles later! BTW, why don't you come down to our SoCal Meet and Greet? You're not that far, I just came back from S.B. last week, it's only a couple hours, or less, away!
My Ride: 2004 BMW 645 black sapphire metallic, 19" Style 166 (245/40 & 285/35 w 15mm spacers)
[quote name='nicke60gre' date='May 13 2006, 10:05 AM' post='281790']
Hi guys,
Does anyone know, where from the speedometer takes the signal, front, or real axle?
I think its via the abs/dsc sensor, but on which one axle?
I think also that, it can't be from both the axles.
The speedo signal comes from rear axle ABS sensor which is mounted on the rear left side.
Allar
Hi guys,
Allar
Originally Posted by Don Juan' post='208812' date='Dec 8 2005, 03:06 PM
very nice indeed....
some other opinion, the car looks ggod, just a bit higher becasue of the difference in diameter... also remember your speedometer is affected with this change...
I opted to stick as much with the factory recommendations for my car since its not an M5... so for the fronts I have 245-35-19 in a 8.5x19 rim and the rears I have 285-30-19 in a 9.5x19 rims.. the front and rear are the same diameter now plus i have the staggered look...
Curious,
Do you happen to know the offsets on your rims?
Thanks
Here's mine, with 255/30 and 295/25 PS2, factory sport springs. I have heard it rub once, fully compressed, ont the left rear. Very happy. BTW, I tried the 245 and the 285 when I mounted the wheels ( I actually got 8 tires and moutned two each to be sure). To me, the 245 just didn't look as gooe as the 255/30, and the rears were a no brainer. Hope this helps.
Allar
Allar
245/40/19 front
275/35/19 rear
Bridgestone RE50A W RFTs. Pressure 30 front - 25 rear / 30-30 when car is loaded (for a smoother ride) ...much better on road bumps, I'm a happy/safe RFTs user now
I milled off 2mm of the front rotors outter surface, where the wheel mounts and I have no rubbing issues now.
There is much "meat" to mill there, I think 8-9 mm, so 2mm off, is a quite safe job.
I could shape 2mm and off the wheel too, but there is no reason now. (I don't like to mod the wheels at all)
I have also 7mm spacers fitted on the rear wheels, no rubbing on road bumbs so far, but I haven't check it loaded.
Speedo is 100% accurate now (95% with stock wheels). Double checked, when speedo reads 170km, my portable Destinator GPS system reads 170
I just bought a 535 and put my 166's on and i am rubbing in the front over almost every other bump
I was planning on getting the 245/40/19's for the front but I just found out that that size was discontinued in the continental sport contact 2. I really don't want to mismatch the tires so if someone knows where I can find 245/40/19's continental sport contact 2 please tell. If not does anyone have any other suggestions on what tires I should run?
I am new to the BMW world so please be gentle.
My Ride: 2005 530i, Premium/Sport Packages. Heated Seats, Sat Radio, Mystic Blue Metallic and Dakota Gray Leather interior. Active steering and headlights, M5 166 wheels
I think I am going with th 295/30/19 on my rear and keep the 245/35/19 on the front. Hopefully I can find two more Falken tires for the rear.
My Ride: 2006 525i Carbon Black MSport with 166 rims & Achilles ATR Sport 245/35 (front) and 275/30 (rear)
Hi BlueMajik
I know its been a while but how did you go with those 295/30/19 on the rear? Any rubbing?
I thought 255/35/19's on the front wouldn't have been a problem either?
asinner
May 6, 2015 06:03 PM
