08 550i Check engine light
Old Nov 1, 2007 | 01:13 PM
code5's Avatar
Anyone know if i replace my Catalytic with straight pipes, is there a way to trick the computer for the Engine light to come on.
I know for sure that my G35 i had straight pipes on and my check engine light came on. The G forums told me to buy this extension that you screw on the straight pipe to trick the ECU.
Old Nov 1, 2007 | 02:12 PM
my530i's Avatar
Irresponsible thing to do. Put the cat back.
Old Nov 1, 2007 | 02:16 PM
jet190rs's Avatar
It sounds like they're talking about tricking the O2 sensors (lambda probes). I'm pretty sure there are also O2 sensors after the cats, so if you remove the cats, then those O2 sensors will throw the CEL as they sense the "dirty" exhaust. You can try buying O2 simulators that'll pass off the correct message to the ECU, or you can try doing something like this -
http://forums.vwvortex.com/zerothread?id=1366095
Old Nov 1, 2007 | 09:12 PM
code5's Avatar
Jet190rs, Thanks for that info.... I thought that would work, just making sure since it's a totally different car.
Originally Posted by jet190rs' post='488760' date='Nov 1 2007, 03:16 PM
You mean to come off right?
You can try contacting the various BMW tuners to see if they have software that'll turn CEL off.
Old Nov 7, 2007 | 02:54 PM
bosg's Avatar
My Ride: 2004 5.30i Saphire Black on Auburn, Sports Pckg, Premium Pckg, Sound Pckg, HUD, Cold Weather Pckg, Heated Rear Seats, Electronic Rear Window Shade, Foldable Rear Seats with Ski Bag, European Reflectors, Active Steering, PDC, 19" AC Schnitzer Type II, Front: 245/35, Rear: 275/30 Toyo T1S, H&R Sports Springs, 35% Tinted Windows, B&B exhaust w/ custom straight pipe
removing cats and adding straight pipe usually doesn't make the engine light come on. must be something else. I remember a while back the engine light came on for my car and wouldnt go away. Service advisor told me that the E60s, when the gas cap is not fully tightened, engine light will come on and it will take 20 startups till it goes away
DavaiLave
Aug 2, 2022 02:16 AM
thesalboy
Apr 8, 2015 09:13 AM
Stranger12
Apr 5, 2015 10:42 AM
Sic Sticks
Mar 30, 2015 01:17 PM
laz1left
Mar 11, 2015 11:15 AM
