07 e60 525xi Rear Suspension (Coil Springs)
Old 10-09-2019, 09:25 AM
Sweat's Avatar
Originally Posted by cmyachtie
Google is your friend....for these prices I would pass on the used parts choice.
see this link for OEM springs or any other option if you so desire
https://www.carid.com/2004-bmw-5-ser...5D%5B1%5D=Rear
Checked out the link punched in my car 07 525xi and it says it doesn't fit my car. I tried looking up by my vehicle and it says nothing is available. Since my car is an E60 shouldn't these springs be interchangeable in regards to the part 04-10?
Old 10-09-2019, 11:00 AM
cmyachtie's Avatar
My Ride: 2004 545i+BT+AUX+Coding
Engine: N62
good question, would have thought they are the same but maybe try talking to them and ask what their return policy is.
Old 10-14-2019, 07:37 AM
Sweat's Avatar
Hello audiophool and cmyachtie ,
I appreciate the help!! Got the change done by buying using used springs and swapping them in with the shocks/strut assembly. I wanted to give you guys a heads up if ya'll doing a replacement on the rear end that the DIY's don't tell you is to use a ball joint removal tool to take the ball joint (attached to the swing assembly) (part cost at Napa $13) off to ensure you can push down on the break assembly to place in the new the new assembly in. The DIY's advised me to use a rubber mallet and pound on the bottom piece of the ball joint unseize the part. I wanted to take the cautionary approach and not risk damage to the threading on the ball joint.
Old 10-14-2019, 07:55 AM
audiophool's Avatar
My Ride: 535xi
Which ball joint are you referencing? https://www.realoem.com/bmw/enUS/sho...diagId=33_1165
Old 10-16-2019, 06:06 AM
Sweat's Avatar
Part Number 6 on the link below, I had to unseize the rubber mount on it so I can push down the rotor to allow enough room to place the shock/strut assembly in.
https://www.realoem.com/bmw/enUS/sho...diagId=33_1171
h100250
12-31-2011 12:19 PM
Jay8282
03-08-2010 02:25 PM
superlubricity
12-29-2009 09:20 PM
mpa90
6 Series Discussion
12-22-2009 11:45 PM
freed0m
06-03-2008 01:00 AM
Quick Reply: 07 e60 525xi Rear Suspension (Coil Springs)
