You guys Rock!
My Ride: 2008 535i:
1992 Camaro RS:
I think Paint Job and on the Cheap CAN go together... it just inolves us learning it. I've never painted a car but i'm sure if I bought all the materials, practiced a little on other folks cheap cars, and got comfortable it would be even cheaper than Maacos.
IDK... anyone around here paint their own cars? i'm really considering this for future reference.
As for materials: Paint gun, sanding equipment, primer, filler, and paint is all you need to start. The trick is finding a location where the paint can cure properly. Most body shops use paint booths (Apparently the MAACO one had mosquitoes in it). I know several people that have done paintwork on their own cars as a beginner and got good results.
LOL- written on the butcher paper- "Do you know where my penis?"
Nice write-up. I don't know if you are supposed to use galvanized bolts on an aluminum block. You might get some corrosion, so I'd keep an eye on it.
OP saw your link to this post on another post. I like the paper idea. Man are you a talker! LOL I can get a lot of your personality and character jut from this post. Nothing wrong with being a worrier and going through preventative maintenance but you'll be spending money and wasting time on things that do not need them. JMO.
As far as paint goes...if i painted my whole car myself and did clearcoat I'd spend about $200 in materials at most...so cheap and paint definitely go together. If I were to do it myself and count my time and pay myself $40 an hour altogethe from start to finish looking at about 10 hours from start to finish because I'm a picky perfectionist which includes prep wetsanding, filling/feathering dents, taking out lights and trim and taping off...also sweeping up shop and so forth...it would probably be about $600.
I spent about $50 to paint my whole front end...Hood and fenders...I blended half of fenders and half of hood and clear-coated everything. If you ever get to painting (which I am sure one day you will) take your environmentals into consideration. For instance there are no bugs at peak of day and clearcoat will take at least 1.5 hours to setup so it will not be tacky. So for example sun sets at 5pm and it takes 1.5 hours to tack them you want to have it tack before 4pm so it must be finished by 2:30pm....and if it takes you a 1 hour to tape, drape plastic, run the tack rag, spray, clean and re-spray the re-clean (using two separate guns is ideal) you have to start probably by 1:00pm. Let me know if you get into this and have questions. Or anyone.
![You guys Rock!-img_0811.jpg](https://5series.net/forums/attachments/e60-discussion-2/129842d1482364309t-you-guys-rock-img_0811.jpg)
![You guys Rock!-img_0810.jpg](https://5series.net/forums/attachments/e60-discussion-2/129841d1482364309t-you-guys-rock-img_0810.jpg)
![You guys Rock!-img_0643.jpg](https://5series.net/forums/attachments/e60-discussion-2/129840d1482364309t-you-guys-rock-img_0643.jpg)
man this post ! LOL
For the berry stains wash your car with a ph neutral soap and add some vinegar to it to make the soap acidic that should help. You and your car may smell like a salad for a short time but .Then rinse, Then after that use a claybar and some soapy solution rinse, then wash car again with normal car wash soap. good job on the overhaul
