xi owners, please help...
I'm looking for a cheap set of winter wheels for my 530xi. I'm searching Tirerack.com, but I'm not sure that they are aware that the xi's require a different offset. Anyone know of a set of wheels that I could use in a winter setup? I have a set of winter tires, size 225/50-17. Thanks in advance for your help.
My Ride: 2007 530Xi - Navigation, Premium package, Steptronic.
Originally Posted by ExGMan' post='458539' date='Aug 14 2007, 08:28 AM
cmansbimmer has a 530xi and has all the facts regarding the offset. You might want to PM him. Once you have the number, then call Tire Rack and ask. I think the $129 Borbet wheels look pretty good. Wheels+tires+balance+delivery, all for around $1200. Not too bad...
Our offset is ET43. On the standard RWD cars, it's ET20. Therefore, when looking for wheels you need an offset of at least ET38ish. 3 series wheels actually have a high offset and can work well with our car. However, I wouldn't go beyond a higher width than 8". Therefore, I would look for a wheel that is 18x8 or 19x8 with an offset of around ET38-40. If you're unsure of the end result, in terms of how far out in millimeters, the new wheels will push out, use this:
http://www.1010tires.com/WheelOffsetCalculator.asp
You can also go to www.realoem.com and check out the specs of all OEM wheels, when it comes to offsets. This will show you all our options, in terms of what wheels we can run on our car. Believe it or not, almost all the stock wheels in both 17" and 18", are available for our cars and the standard ones. Just note that the offsets are different, therefore, the xi wheels that LOOK the same, have a different part number.
Both sites are fairly self explanatory and user friendly.
bestofthebest
Mar 28, 2016 02:47 PM
th3h1ghlander
Oct 9, 2015 07:40 AM
ucsbwsr
Sep 19, 2015 10:58 AM
