wrapping interior
My Ride: 08 528i
Is there a known best approach to remove the black trim out these pieces so I can wrap them or do you guys just cut with a knife between the black plastic and the wrap vinyl? It looks like the silver tab on the cig lighter door needs to be drilled out.
My Ride: 08 528i
The more I look at this the more I realize the trim is not suppose to come off, it's almost melted to the plate and even if I got it off, putting it back would not sit as well as it is now.
It looks like I'll have to just cut precisely on the edge and hope the vinyl doesn't start peeling off. I removed the DTC and trunk buttons and for the cig lighter door I drilled out the back of punched material, it turned out to be plastic, but carefully drilling it worked out. When I put it back I'll probably just glue it on.
My Ride: 08 528i
Different story on the arm rest trim, I managed to get the menu button frame off the trim but I broke 2 1/2 of the plastic pins that fit in the holes. I drilled out the material out of the holes from the trim, drilled a couple holes where the pins use to be and I'll have to mcguiver something to make sure the menu trim doesn't move around when I put it back together.
My Ride: BMW
You actually cover the whole thing with vinyl wrap. Use a heat gun or hair dryer to mould it into the crevices and then use a hobby (new blade) to cut out the areas of the chrome piece and switches that don't come off.
I wrapped my rear trim piece. It's a pita to get off but a paint can opener works well. It has a small 90 deg lip that can be used to grab along the side to pull straight back. Also a credit card to help release the clips. Warning the clips are not replaceable. I bent mine and discovered this so had to straighten it out. You can only get new clips with a new panel!
My Ride: 08 528i
Yeah I now what you mean about the clips, I bent one of mine so I figured no big deal I'll just order a couple, turns out, they come with the plate only!! I straighten it too and hope it holds when it goes back in
I was trying to see if I could remove the cig lighters so I could wrap the plate and then install them back, but I've not been able to do that. did you just cut it around the cig ligther circle? The circles are lit.
