Wiper fluid is low.
My Ride: 2007 Mercedes Benz e63 AMG
I know this has to rank up there with the all time silly questions, but is there anything I need to ponder before buying wiper fluid? I am barely competent to replace the wiper fluid, and didnt want to top it off with the same stuff I use in the wife's car if there is something that is clearly better.....
File this under DUH, I know...
Thanks for any thoughts...
My Ride: 2011 E92 335i M-Sport 6MT
There's also BMW's own concentrated windshield antifreeze solution which you dilute with (distilled) water. Well worth it since one small bottle can be diluted into gallons of windshield fluid that can last a really long time.
My Ride: 2007 Mercedes CLS63 AMG
Designo Graphite with white leather interior
Keyless Go, Heated/Ventilated seats, Parktronic
For roughly $1, just buy the pre-mixed stuff. Why bother messing with the "BMW fluid" that you have to mix yourself? I know the freezing temps are over for quite a while (especially in Kentucky), but imagine if you mixed the fluid WRONG and added way too much water. Now you have a problem come winter time. For as inexpensive as it is, just buy the pre-mixed.
My Ride: 545i SE Oct 03 (53 plate) 19" Alpina Classic rims
My experience was different and it suprised me.
my wifes 116 had blocked washer jets - took it to the dealer and it turned out that the washer additive i had added (Halfords) had reacted with the BMW screenwash (?probably different pH's) and a precipitate had formed.
BMW wanted >?100 to dismantle the wheel arch covers etc to get to the washer bottle to flush out. The stealer said that this had happened before.
It took me approx 1 hour to flush the tank with a hose (+hot water) to remove the 'gunk' that was in the washer tank.
My advice would be to use any washer fluid, but make sure that the bottle is empty, prior to the fill up.
My Ride: 640D MSPORT GT
i use halfords because of cost ,it works resonably well,on all dirt flys grease etc but with the headlight wash and motorways it tends to empty a gallon a ong journey to wales and back so quite costly around a gallon a 1000miles on average. i have found.a tip i found is that the blades must be wiped clean every time you refill.fluids affect the efficiency with a smear of black greasy residue.
My Ride: 06 530XI Sapphire Black, Black Int. 6sp, Cold, Prem
Any problems using using an off-brand when cleaning your headlights - stuff has a tendency to get all over the hood of my car.
My Ride: 2004 530i Titanium Silver Metallic w/ gray leather
Premium Package, Cold Weather Package, navigation, iPod retrofit
Is the BMW concentrated fluid available anywhere but at the dealer?
costco simonz for me. ?3 for 5 litres of concentrate. x5 has a 7.5 litre washer tank on it , so id be poor is i used bmw stuff.
seems to go through loads due to me having the headlights on constant. As they are xenons it sprays the light too. Ah well
