Winter Tyre Speed ratings
Model Year: 2015
Engine: N55
Solved, after much effort my local dealer phoned and has got me some Conti Winter Contact TS 790v's at ?115 each fully fitted.
My first choice would have been the Blizzak LM25's, but they come in at ?145 each, I think the Conti's are a better deal.
Originally Posted by dlevi67' post='356990' date='Nov 17 2006, 01:27 AM
Well, allow me to point out that winter in Finland is likely to be a little more challenging than in Wiltshire...
But I agree. If you need winter tyres, then doing 160 kph is plenty enough.
![W00t](https://5series.net/forums/images/smilies/imported/w00t.gif)
The speed limits are even lowered to max 100 km/h on the freeways and to 80 on normal highways. :thumbsdown:
I laugh only so my crying wouldn'd show
I hate the winter!
My Ride: 2010 523i. Alpine white, dakota leather, 8 speed auto, VDC, bluetooth, HID lights, parking sensors, sport seats, black window trim, tinted rear windows
1988 Ferrari 328 GTS, nero on rosso corsa.
1992 Mazda MX-5 / Miata
2009 Ford S-Max 2.5T
I hate the winter!
2 days ago I had H rated 225/50R17 Dunlop Wintersport M3 runflats put on in place of the 245/45R17 setup. I complained that they didn't have V rated tyres especially since a colleague has similar size V-rated Conti TS810's on his A6 3.0TDI Quattro. Apparently they couldn't source Vrated runflats in Poland in my size.
First impressions - wow the steering has significantly lightened up and the traction control light seems to be on more often :-). No idea yet how they perform on snow or in the wet although I've heard complaints that they can be slippery when it's wet.
Model Year: 2015
Engine: N55
Traction control light on is bad news, it means the tyres are losing grip and the enige power is being reduced.
My Ride: BMW 530i 05
M-technic Silvergrey whith beige dakotaleather
I have Conti TS 810S! XL 245-40-18 WR !!! Okej it is a litle bit overkill but it is better to be on the safe side
sometimes higher rated W or above are chaeper than some V tyres.
Take a look on
http://www.blackcircles.co.uk
and see what you get
Personally, I would NEVER use a lower rated tyre than that fitted by the original manufacturer. If you have an expensive accident, the insurance co are likely to try and find a way out. The fact you were doing 40 at the time wouldnt hold up as they could claim any accident in which tyres were a factor was due to previous high speed use outside of the tyres rating.
I wouldnt risk my ?27k car on downrated tyres....
cheers
steve
Take a look on
cheers
steve
The other thing is that the wintertyres should be good in really bad conditions.
Some of you might not understand, but it only needs to be one day with bad contions
and some bad luck + a bit too much speed when you really need the best tyres possible.
The winter brings this matter really out! If you drive some thousand kilometers every year
and every winter you learn this.
Why do the best rally and F1 car drivers come from a tiny country like Finland (pop 5,3 M)?
![Innocent](https://5series.net/forums/images/smilies/imported/innocent.gif)
"Personally, I would NEVER use a lower rated tyre than that fitted by the original manufacturer. If you have an expensive accident, the insurance co are likely to try and find a way out."
This is no problem overhere.
The insurance companies understand that the best winter tyres comes with lower rated tyres!
Model Year: 2015
Engine: N55
It ain't in the manual so it must be wrong!
Common sense is a lost attribute in the UK, and the US for that matter!
[sorry - can't upload the stuff. Will try again tomorrow, but the label clearly shows H rated M+S tyres are meant for this car, KAF]
Originally Posted by dlevi67' post='357760' date='Nov 19 2006, 12:17 AM
Erm, higher incidence of driving madness and reckless behaviour?
It IS in the manual. This is my tyre label - apologies for the quality of the photo, but look at what's approved by BMW...
