Wing Mirrors - 2 things...
My Ride: G30 M550i
Model Year: 2018
Originally Posted by ISUK' date='Jan 17 2005, 07:51 AM
I find the dipping function can be a real pain in the a** as it leaves you completely blind down the passenger side of the car. As others have said it's ok for judging the kerb but it goes so low that you've most likely hit the kerb with your rear wheel as the mirror only shows you the ground between the two doors.
I'm not sure who programmed this much mirror travel in BMW's technical department but they ought to rethink it? :thumbsdown:
[snapback]80015[/snapback]
Originally Posted by Rudy' date='Jan 17 2005, 01:38 PM
[quote name='ISUK' date='Jan 17 2005, 07:51 AM']I find the dipping function can be a real pain in the a** as it leaves you completely blind down the passenger side of the car. As others have said it's ok for judging the kerb but it goes so low that you've most likely hit the kerb with your rear wheel as the mirror only shows you the ground between the two doors.
[snapback]80023[/snapback]
[/quote]In the next version of iDrive...
My Ride: F02 LCI Individual
Model Year: 2013
Originally Posted by Zaphod' date='Jan 17 2005, 10:31 AM
How do you fold the mirrors?
[snapback]79979[/snapback]
The mirror adjustment is fine for driving. The dip function when reversing cannot be adjusted (unless someone can tell me otherwise) and it goes too low to be useful.
Incidentally the motors in my mirrors switch off as soon as the mirrors have folded so I don't have the noise others have complained about.
Model Year: 2013
[snapback]80556[/snapback]
If you have it set that you see more of your car and less of the street, you see less when it tilts down.
My Ride: Nothing to boast about!
I get a little bit of noise when they completely folded.
And I adjust the mirror such that I see a little part of the car body. When they dip in reverse, I could see clearly the kerb etc. The only problem is I am so used to using that mirror to judge my parking that I can't get used to it showing me the road surface instead. So I am not using it unless I really need to; for example parallel parking or parking next to curb.
Originally Posted by SueBMW' date='Jan 19 2005, 04:16 AM
If it bothers you & is too low to be useful, why don't you just flip your switch to the other side so it doesn't dip at all?
Vman33
03-14-2022 04:43 AM
bestofthebest
03-28-2016 02:47 PM
