Window operation possible after taking a plunge?
My Ride: G30 M550i
Model Year: 2018
Keep in mind the obvious fact that if the car is submerged, there is a strong likelyhood that electrical systems would short out very quickly so even if the car would allow the operation of the windows, they may not work after a few seconds...
My Ride: 2008 550, Carbon Black Metallic, Natural Brown Dakota Leather, Sport Package, Sport Automatic Transmission, Cold Weather Package, Power Rear and Manual Side Sun Shades, etc.
Retired - 2004 545 SMG, Black Sapphire Metallic, Auburn Dakota Leather, Cold Weather and Sports Packages, Power Rear and Manual Side Sun Shades
I saw a story about just this subject on television one or two nights ago (cannot remember which show). The windows did continue to work for a short while the front end was submerged. The trick is to get out quickly, while the car is on or near the surface, before the pressure prevents the windows from operating properly. Myth Busters also covered this topic, focusing more on the pressure issue than on the electrical system. They tested the tools designed to break windows and they worked remarkably well. The trick to breaking a car window is to scratch or nick the surface. After that, very little force is needed.
My Ride: 2003 330i (for sale)
On order: 2008 550i Sport
This topic has been on my mind also...I live in Minneapolis and the recent freeway bridge collapse has again illustrated the need to be prepared in an emergency. The press coverage has included a lot of stories about what to do if you find yourself in a submerged car. The general consensus is that power windows will work even with the car submerged as long as the key remains in the ignition and not turned off (eventually the car will lose power, but the point was made that power windows not working is not the primary concern).
This does beg the question - what about BMW's and other makes that have a battery disconnection mechanism? I would assume that in most cases a scenario that involves the car ending up submerged will likely include the air-bags deploying and based on the info in the above posts, the battery would be disconnected.
It was also noted that many safety-hammer type devices designed to break car windows may not work if the car fills quickly with water (hard to swing a hammer in water), and that spring-loaded devices are better.
www.resqme.com has a device that is widely recommended.
if this event should happen, id agree to try to open the windows asap before/as the car begins to submerge, even if that means breaking it. in addition, the sunroof. i remember my mother telling me a story of her and her cousins before in florida since they used to live there. she had her 1982 corolla and somehow went into the swamp because by the turnpike before jacksonville i think she said because of some wreckless driver. the car was submerged except for the top/roof so the sunroof was their only escape.
My Ride: Collected Sept 2009 - BMW E90 M3, Silverstone II, Novillo Black leather, 19" M Double-Spoke alloys, High Beam Assist, Electronic Damper Control, Voice Control, PDC, USB, DAB, High Gloss Shadowline, Sliding armrest, Trim Finishing in aluminium grey.
I think I recall seeing someone using a Centre Punch to break a car window. The device barely touched the glass when it shattered.
It appears to be possible to open a door on a submerging car as long as the water level hasn't risen beyond say, 35% ot 40% or so of the total height of the car door. If it has reached the window line I reckon you'd never get the door open until the car filled and the pressure equalised.
I've also seen cars fully submerged under water and the lights were still on. I'd surmise that electric windows would still work as well. However, unless the pressure has equalised on both sides of the glass (the car has to fill with water), I don't reckon that neither the manual winding or the electric motor has the power to lower the window glass because the outside pressure is pressing the glass against the frame with too much force.
When using hammers under water (as in a submerged car), the water seemed to disspiated the potential energy in the striking movement so the required breaking force was never transferred to the glass.
Just some thoughts.
Just some thoughts.
My Ride: 520d LCI, old engine, manual, black dakota, platingrau II, standard (242?) rims.
My Ride: 2004 545i Silver Grey Premium Package, Sport Package, Dynamic Driving Package
