Why is my climate control always on?
Old 01-03-2006, 03:09 PM
Stranger's Avatar
My Ride: Nothing to boast about!
It's the fan that cannot be switched off permanently, much like the recirculation mode. For safety reason?
But the aircon it can be turned off. Before you shut down the engine:
1. Turn the fan speed knob to the lowest (or any speed you prefer). This will get rid of the auto mode. If the auto mode is on, the system will attempt to regulate the temp to your setting even if the aircon comp. is not on; and you might get strong and loud fan blowing at you.
2. Press the snow flake button to off the compressor.
3. Press the off button in the centre of the fan speed knob.(Optional actually)
You are set. The next time the car is started (even after the sleep mode), it will only turn on the fan at the speed that has been set. The aircon will not kick in.
Old 01-03-2006, 03:20 PM
DD694's Avatar
My Ride: 2006 550i Sport Package, Cold Weather Package, Premium Sound Package, Comfort Access, Xenon Headlights, Adaptive Headlight Control, Navigation System, Steptronic Transmission. Silver Gray Metallic with Gray Leather. Added Red rear reflectors. Swapped stock Style 124 wheels and Bridgestone run-flat tires for BMW Style 125 5-Double Spoke wheels, 8" x 19" front, 9.5" x 19" rear with Michelin Pilot Sport PS2 tires, 245/40YR-19 front and 275/30YR-19 rear.
You can through iDrive control the "intensity" of the HVAC system to minimize being blasted when the car starts with A/C in Auto.
Old 01-03-2006, 03:21 PM
Delta's Avatar
Like what the others have said, there is no way to keep the climate control off. All BMW's are like this, because even my son's 00' E46 does this. Just as suggested, before shutting off your car, leave the fan speed to it's lowest setting.
That is another thing on my son's E46. When the climate control is set to "Auto," when you start the car, it is never fully blasted. It only starts to blast once the car is warmed up (once the temperature needle leaves the "Blue" zone).
Old 01-03-2006, 03:34 PM
carfreak's Avatar
My Ride: 530i
I had an 03' 330i (E46) and it never did this. The only thing that bothered me was the unexpected blast of air.
sxybeemr
06-20-2023 10:13 AM
EuropeanArtz
09-29-2015 04:26 PM
lcc014
DIY: Do It Yourself
09-10-2015 05:57 AM
bimmerspeed
09-03-2015 09:29 PM
bimmerspeed
Frequently Asked Questions
09-01-2015 05:09 PM
Quick Reply: Why is my climate control always on?
