Wheel Upgrade Question
Old Feb 4, 2008 | 04:01 PM
directcj's Avatar
Hi there-
I've got an 05 e60 which needs a new set of shoes/tires. I'm thinking of upgrading my wheels/tires so was looking at getting 166's or 124's with OEM tires (hopefully they'll have lo-miles). Will I have an issue by going to OEM 166 rims/tires (from an M5) on my 525? Other than being called a poseur of course
Also, with the OEM tires off the 124's or 166's. What sort of tire should I expect? I was able to get 48K miles on my OEM Conti's (on a 138 rim) and possibly more. I just got an unrepairable flat so I'm thinking of upgrading wheels.
Old Feb 4, 2008 | 07:16 PM
either of the wheels would fit fine. for the 166s, you wont be able to use the tires off of an M5. recommended tire sizes for that wheel on a non-M e60 are 245/35/19 front and 275/30/19 rear.
Old Feb 4, 2008 | 07:36 PM
directcj's Avatar
stock oem m5 tires are 255/35/19 and 285/30/19
you're saying I need to get narrower tires then? what happens if i use the stock tires? I'm assuming they'll rub right? sorry for the newb questions....
Old Feb 5, 2008 | 10:06 AM
pms replied. good luck with the wheels.
Kasmo
Jun 27, 2024 06:02 AM
socale39
Sep 5, 2023 08:30 AM
chadillac2000
42
Sep 13, 2017 11:15 AM
srogers535x
14
Apr 26, 2015 09:39 AM
addy33
Apr 13, 2015 04:40 AM
