What would wake up your E60?
Old Apr 25, 2012 | 02:22 PM
louisrai's Avatar
My Ride: 2008 BMW 535i Silver - E60
I was reading this: http://www.bimmerfest.com/forums/sho...passenger+seat
then I realized that I get "High Battery Drain" message sometimes. Because this message doesn't come out too often, I chose to ignore it. However, I do get the following experience with the battery:
when I sit in the car, and turn everything off, every few minutes, the CD starts to roll and I can hear some equipments start to run...is this normal?
Is that like the car detects you sitting in the seat, so turn on some equipments? Or this should not happen?
What is supposed to wake it up in normal situation?
Thank you.
Old Apr 25, 2012 | 07:34 PM
colb666's Avatar
My Ride: E91 sport + touring
From my understanding the first module that awakes the car is activated as soon as it detects the doors being unlocked.
Old Apr 25, 2012 | 07:44 PM
AchtungE60's Avatar
My Ride: E60 530i
same as my understanding.
Old Apr 26, 2012 | 03:42 AM
thomas finlass's Avatar
My Ride: 2006 525i M Sport Carbon Black Cream Leather Interior
If you sit in your car and switch everything off, after a minute or two the car will close all the air vents inside/behind the dashboard...maybe this is what you hear.
Old Apr 27, 2012 | 01:11 AM
BLooD's Avatar
Yup, also its switches the fuel pump off as well.
Old Apr 27, 2012 | 05:30 AM
BMW535xia's Avatar
do you have comfort access option? that could be one of the culprits...so i've heard.
Old Apr 27, 2012 | 10:50 AM
louisrai's Avatar
Yep, mine has comfort access. I don't think it is closing the vents. It happens constantly, not only once.
Old Apr 27, 2012 | 11:28 AM
Liam's Avatar
Had the same problem... in the end it was a faulty comfort access sensor. If you have a comfort access sensor not working, it is most likely the culprit. Easy way to test this is by disconnecting it and see if the problem goes away
Old Apr 27, 2012 | 11:52 AM
louisrai's Avatar
Is it the one box below the spare tire?
Old Apr 27, 2012 | 12:40 PM
Liam's Avatar
The sensors are in each of the doors and the trunk. If you have the key in your pocket, does comfort access work in all the doors? What I mean is that when the car is locked, can you unlock it from all the door handles? If you can't from one, then you know which sensor is shot.
Kasmo
May 7, 2019 03:30 AM
mister5kevin
Jul 28, 2015 04:16 PM
jasonkhasnofriends
Apr 27, 2015 12:41 PM
Quojo
Apr 1, 2015 04:00 PM
ZeZe
Oct 15, 2003 12:58 PM
