What are those 5 LED's
Old Jun 13, 2007 | 10:56 PM
Aloha's Avatar
Above the front turn signals on both sides of the car and why arn't they on?
Old Jun 13, 2007 | 11:19 PM
Aloha's Avatar
These 5 led's are suppose to light up the amber strip just above the head lamps and wrap around above the turn signals
Old Jun 13, 2007 | 11:42 PM
Bambi's Avatar
My Ride: 2008 X6 xDrive 3.5
Yup, they are supposed to be on. Your previous CIP update has deactivated them (big program bug). You just need to go to the dealer and ask them to give you the most update CIP and they will be back alive again.
Old Jun 13, 2007 | 11:59 PM
Aloha's Avatar
CIP update??? Hmmmm. Thanks. I was going in anyway but how would these be indepandent of the regular lighting??
Old Jun 14, 2007 | 12:43 AM
MacSid's Avatar
My Ride: G30 530i M-sport
Model Year: 2018
These are not actually independent of your regular lighting - the LED's and the "eyebrows" light up when you turn your lights on (or when they come on in auto mode). However, there have been issues with some of the CIP/Progman upgrades, which have left them disabled. If you switch on your headlamps, and these lights do not light up, I would suggest that your CIP is the culprit and see about a further upgrade.
MacSid
Old Jun 14, 2007 | 01:28 PM
Aloha's Avatar
Cat eye's (as the dealer called them) Have been draining peoples battery's. Hence they were disconnected via software i believe ver. 19.
Apparently everythings has been updated so now i need to go to the dealer and let the carr set a whole day for programming. Thanks for the help folks.
MacSid
Old Jun 14, 2007 | 03:27 PM
kscarrol's Avatar
My Ride: E90 M3
Model Year: 2011
Not sure I buy the dealer's explanation as they only come on when the car is running and the headlights are on. It's a bit like saying the headlights are draining the battery so they were disabled... Oh well, at least the dealer is going to correct it for you.
Old Jun 15, 2007 | 03:22 AM
iversonm's Avatar
My Ride: E46 330, E60 550 on order: Carbon Black/Natural Brown, 6MT.
If 10 little LEDs suck a battery dry under normal operating conditions, I'd check out the battery first.
I'd guess all 10 would pull about 40-50 mA.
Old Jun 15, 2007 | 01:54 PM
Aloha's Avatar
Oh I agree. But not knowing the real deal i will be asking for the correct answer. Apparently it's more the software that was causing the problem rather that the lights themselves.
Old Jun 15, 2007 | 04:12 PM
kscarrol's Avatar
My Ride: E90 M3
Model Year: 2011
Correct, purely a software error corrected by a later version. I don't ever recall any issue with the LEDs draining the battery. I was really just pointing out how some folks, rather than saying they don't know why tell a lie to cover their tracks. If I don't know something I say so and tell the person that I'll do some research and get back to them with an answer, rather than throwing some sh*t against the wall hoping it sticks! Go get the software up date and the lights will work just fine.
