What sensors are these
My Ride: 2006 550i
my car is an '06 550 with 53k on the clock.
I was doing my brake flush this weekend and noticed these sensors were both weeping with oil residue reaching the bottom of the block.
Quick note: You can only see these clearly when the cowling and air filters are removed like for doing your brake flush.![Wink](https://5series.net/forums/images/smilies/imported/wink.gif)
So how hard are they to replace and what are they?
My Ride: 2007 550i sport pkg 6MT
Those are the eccentric shaft sensor electrical connectors. The two screw plate has an integrated rubber seal to seal the ESS connector stem. The rubber hardens and then leaks.
My Ride: 2006 550i
Thanks for that!
Just found the sensor gasket seals from a BMW dealership on amazon for $15.00 for 2 with free shipping. Phewww going to be the cheapest DIY yet. I noticed in the dealers small writing it was explaining only a 2 year warranty or 24,000 miles.
this may be a place to check if your having oil loss or leaks.
spediegunz
08-30-2015 09:43 AM
