What is needed to get Bluetooth to work on 03 525i?
My Ride: E60 M54
Model Year: 525i 2004
Guys, I have an 13Oct03 E60 525i with M54 with following option in my built sheet.
"S640A AUTOTELEFONVORBEREITUNG Preparation f tel.installation universal"
And my MASK options look like below;
After reading all the posts, I am little confused and would like to know;
Thanks for help in advance.
Note - My dealer here says I need a kit 84640441949, but that does not include the TCU and includes all cable and microphone etc. Is that something different solution instead of replacing the TCU. And if yes, then with the TCU, where is the Bluetooth antenna?
Code:
PHONE_MULF nicht_aktiv PHONE_BUSINESS nicht_aktiv PHONE_PROF nicht_aktiv TWO_MICROPHONES wert_01 TWO_MICROPHONES_JAPAN wert_01 PHONE_VERSION no-phone VA_FLAP_PHONE nicht_aktiv MAX_PHONE_VOL standard SVS_MICROPHONE_PATH analog PHONEBOOK_PRIORITY wert_01 PHONE third_party_phone CAR_PHONE nicht_aktiv USED_MICROPHONES wert_01 TWO_MICROPHONES_TCU wert_01 TCU_TYPE e60_ece BLUETOOTH_FIX aktiv BLUETOOTH_NODES nicht_aktiv BLUETOOTH nicht_aktiv BLUETOOTH_NODES_CCC nicht_aktiv BLUETOOTH_NODES_MASK nicht_aktiv BLUETOOTH_NODES_CHAMP nicht_aktiv BLUETOOTH_01 nicht_aktiv ECE_TELEFON nicht_aktiv VERBAU_TELEFON nicht_verbaut UBERWACH_TELEFON nicht_aktiv TELEFON_TYPE va_tpp TELEFON_AUSSTATTUNG nicht_aktiv TELEFON_TYPE_C08 va_tpp PORTABLE_BT nicht_aktiv PORTABLE_BT_01 nicht_aktiv
- Do I need a new TCU. I am assuming yes, and what is the part number of this new TCU.
- What code do I need to change in the above MASK and do I need to update both CAS and LMA.
- After the TCU and coding is taken care off, do I need a bluetooth antenna?
My Ride: E60 M54
Bit more details on the built information, which need to function if I change the TCU. This is what I have.
S606A NAVIGATIONSSYSTEM BUSINESS Navigation system Business
S672A CD WECHSLER 6-FACH CD changer for 6 CDs
S6UAA VORBEREITUNG FUER NAVIGATIONSSYSTEM Preparation CCC
S700A AREA-CODE 4 Area-Code 4 for DVD
If you aren't set on an all BMW integrated solution, you might take a look at the Parrot stuff. I just installed the Parrot CK3100 in my daughter's 2007 Mazda 3. Works pretty good. It wasn't too bad except for a little cable routing. Essentially the Parrot unit switches the speaker cables to the bluetooth when you get a call and has it's own amplifier, so it is all independent of what's going on with the car stereo. If I had it to do over I might go have gone with the MKi9100, which has a nicer display.
My Ride: E60 M54
My Ride: E60 M54
Digged around bit more and I am sure I need a Bluetooth Antenna. Does anyone here know where is the connector of Bluetooth antenna on an 10/03 E60 525i? What does the connector looks like and where is it located?
Bentley manual says the antenna is located beneath the center console next to the parking brake handle. The retrofit kit wants the antenna to be located under the rear deck in the trunk. Check out this thread: Bluetooth retrofit part number request - BMW M5 Forum and M6 Forums
My Ride: E60 M54
