What is ideal tire pressure for run flats
My Ride: MY 2004 545i; April build; 6 speed; silver grey metalic; black leather; poplar; sport package; cold weather; active steering; xenons .
Has anybody experimented with different tire pressures for the OEM run flats to try to find an ideal pressure that balances handling, ride and noise?
Hasn't anyone been playing with tire pressure on the run flats?
My Ride: E60 530d Sport - Carbon Black, Black Dakota Leather, Media Pack (satnav, bluetooth, CD changer), heated font seats, through load
I'm thinking about playing with them.
Not happy with the grip of the rear tyres. Might just be the torque of the diesel engine, but the back end steps out at odd occasions.
Probably will try loweringt he pressures slightly first. But not for a month or so just yet.
BTW I currently have the factory issued GY NCT 5 tyres (245/40/18)
[snapback]79890[/snapback]
Zero psi. This would be unmounted and stacked in a pile on the floor (hopefully of someone else's garage). You would then have some high quality tires on your car.
Sorry, couldn't resist.
[snapback]80155[/snapback]
I ran 38 psi all around but the tires were harsh even at 32. They get noisy because the large tread blocks wear at a slight angle. This is sometimes called feathering or cupping. Rotation of the tires left-to-right evens out this wear and reduces the noise. BMW does not condone rotation for some vague reason.
[snapback]80212[/snapback]
Still works. FTM is not specifically for just run flats. Incidentally, I run the door post pressures and have gotten along pretty good with my run flats. They might even have been life savers.
