What hard disks work with the USB Audio Interface?
Although I have not been following this here or elsewhere there is a BIG thread on this topic here:
http://www.e90post.com/forums/showthread.php?t=80270
Would this cable be similar or would it still be injecting power to the car?
My Ride: G30 M550i
Model Year: 2018
http://www.amazon.co.uk/LINDY-USB-Cable-Du...r/dp/B000FKP7XA
You would need something like this, I imagine...
Originally Posted by Rudy' post='495164' date='Nov 16 2007, 01:39 PM
I don't think that cable would inject power to the car but where do you plan on plugging in the second USB plug?
Attachment 40555
Attachment 40555
My Ride: G30 M550i
Model Year: 2018
I'm pretty sure that would work then. I've been holding that solution as a "plan B" since my "plan A" is to find a drive that has a low enough power consumption (on spin up) to allow things to work with a single cable powered from the car's USB interface...
My Ride: Oct 2007 LCI e61 530d Touring. Auto, Deep Sea Blue, Natural Brown Leather, Comfort Seats, Panoramic Glass Sunroof, Professional Navigation, USB Audio, Manual Side Blinds
The others on the other board seem to have had success with the The Western Digital Passport range of hard disks. A couple of interesting points:
Even though the hard disk is formatted as FAT32 from the factory, it seems you MUST format it again as FAT32 using the FAT32 format utility from http://www.ridgecrop.demon.co.uk/ind...at32format.htm
Why?? Dunno...
Interesting also is that the WD Scorpio drive (as featured in the WD Passport portable hard disk) does have a low power spin up option. I was interested to know if it was enabled by default (it's set with a jumper), so I took the enclosure apart and found that indeed the low power setting was enabled. Still uses too much power on spin up for the BMW unfortunately. I think the BMW must have current limiting circuitry in it to limit to a max of 500mA, as per the USB spec. Why? I don't know, but probably to stop people doing stupid things like using USB mug warmers
I also think that BMW has to make something that works for USB sticks near 100% of the time. If it started supporting hard disks, everyone would phone up saying: I can't get brandX to work, why not? Etc...
Just my tuppence-worth...
Andrew
Sorry - no signature yet: UK 2008 e61 530d Auto - Deep Sea Blue, Natural Brown leather. Panoramic s/roof. Bluetooth, USB audio, etc.
My Ride: G30 M550i
Model Year: 2018
true...
TexaZ3
05-06-2015 09:54 AM
DerekShiekhi
03-11-2015 05:52 AM
