What does the DSC control?
Old Jan 23, 2015 | 02:13 PM
plowery21's Avatar
My Ride: Alpine White 2010 535 M-Sport
Default What does the DSC control?
Just picked up my e60 from the dealer. Took it in for a check engine light that has been haunting me for months. CPO is running out in June. This time they found a crack in a vacuum hose and replaced it. During the test drive the DSC light came on. According to the paperwork, it was a "permanent malfunction". They replaced the unit..twice according to the paperwork. Apparently one wouldn't sink up after encoding..
Im aware the DSC is part of ABS and steering sensors. The SA told me it is pretty much the brain of the car.. Is this true? What exactly does the DSC control..?
Sure am glad this light came on while they drove the car.. I bet this would cost a fortune out of pocket.
Oh and the replaced my Oil Filter housing. Said they it was starting to show signs of a leak.
Feel like I won the lottery today.
Old Jan 23, 2015 | 03:15 PM
westsidebalto's Avatar
My Ride: Sold: 545i, sport package, cold weather, 6MT
Engine: N62
Brain of the suspension and braking components maybe, but not the brain of the engine or anything in the cabin.
Dynamic Stability Control: BMW Technology Guide : Dynamic Stability Control (DSC)
Basically this system tries to keep you moving in the correct direction. Keeps wheels with traction spinning and not the ones without. It will brake wheels individually to keep your car in control. I believe it was required on all cars (not just BMWs) after a certain model year by NHTSA.
So, are they going to fix it?
If not, it's as if you lost that winning ticket before you cashed it in.
Old Jan 23, 2015 | 03:49 PM
H F's Avatar
H F
My Ride: 2005 545
Here is some info for you . I tried to upload a complete chassis controll systems PDF but it was to large for the maximum file size allowed .
Introduction
ABS - DSC modules
Brake modules
As previously described, BMW plays a
decisive role in the chassis control topic.
Electronic brake management is not only
responsible for ensuring high braking
efficiency at all times, it is also a component of
dynamic stability control (DSC) essential to
maintaining directional stability.
DSC optimizes:
• directional stability when pulling away and
under acceleration and braking
• traction
DSC also detects unstable driving conditions
such as under or oversteering. DSC helps to
keep the vehicle on a safe course within
physical limits.
For this to be possible, DSC must know the
following dynamic driving parameters:
• the yaw rate as a measure of the rotational
motion of the vehicle about the vertical axis
• transverse acceleration as a measure of the
friction coefficient of the road surface
• the road speed
Also detected are the steering angle desired
by the driver and the brake pressure exerted
by the driver at the brake pedal. In addition,
wheel speed sensors provide information
about the speed of individual wheels. The
actual status of vehicle movement at a given
time is determined from the measured values
available. The actual status is compared with
target values calculated in the DSC control
unit. Where current actual values differ from
the target status, DSC is activated and actively
intervenes in the brake system or the engine
control.
Benefits:
With active engine and brake interventions,
DSC provides outstanding directional stability
and excellent traction in all road situations.
DSC counteracts all negative, dynamic driving
forces and thus provides, within physical limits,
the highest degree of active safety possible.
DSC also enhances driving comfort through
relaxed driving.
DSC, the driving assistance system,
comprises various modules that work together
in a complex data bus.
Old Jan 23, 2015 | 09:18 PM
plowery21's Avatar
All, thanks for the info. this is what I was thinking too. Either way it sounds expensive.
westsidebalto they did replace the DSC unit under my CPO warranty for $50.
bmwmonkey
Aug 10, 2015 10:20 AM
iNDOLiFE
Bluetooth & Cell Phone Forum
Aug 4, 2015 07:06 PM
psam550
Aug 2, 2015 02:27 PM
sebash
Jul 30, 2015 12:40 PM
525d MSport
F10 Discussion
Jul 12, 2015 07:03 AM
