What could it possibly be?
Every time the car is coming to a full stop the car jerks! its not so bad when i go really slow and let the car almost stop on its own but when im going fast and hit the brakes to a full stop it jerks even more obvious. Mean time, I also notice, in steptronic mode, when the car is not moving and I downshift from M2 to M1, the car jerks with a small bang, so my question here is this a common problem? has it happened to you? and how did you fix it?
i appreciate all your help
The transmission issue can have other symptoms, or it could be a source of a hard jerk when shifting gears.
This shaking/jerking sounds a bit like the control arm bushing problem seen on the 3 series - when the bushings wear out, the wheel can move a couple of inches during breaking, usually in rapid succession - there are other suspension problems which can have similar symptoms, so you'll need to get the car to a good repair shop to get things figured out.
I have a 545i and experience the same thing, it's the transmission shifting down when you come to a stop, most likely from 2nd to 1st gear. very annoying, never felt anything like it even in the cheapest cars.
That jerkiness feeling should not be there in manual mode though because you are manually shifting it to M1 when you stop.
