What can cause occasional fluctuating RPMS on a cold start?
My Ride: 2007 Sapphire Black Metallic 525i. Beige Dakota Leather, Premium package, bluetooth, BMW Assist, Xenon adaptive lights, Sirius radio
Willing to throw some money at the car to see if something will fix it. The dealership cannot Duplicate the problem and they have had it a week. No codes, no lights.
Driving me bonkers and am willing to throw some parts ath the car to see if it fixes it.If not I amy trade outside of BMW,![Frown](https://5series.net/forums/images/smilies/imported/sad.gif)
At present when this occurs the car lunges when you put it in gear and will return to normal and lunge again.
My Ride: 2006 BMW 550i
i'm not sure which ac compressor came on your 525, but it could be your car lunges everytime the compressor kicks on. the car is programmed to idle higher everytime the ac kicks on. now if your car has the variable compressor like i know my 550 does, then you shouldnt really have lunging going on, at least due to the ac kicking on.
turn the ac off and see if the problem goes away.
think this could be why it only does it sometimes?
Does the compressor always kick in when the climate control is in automatic? Seems like I read that the compressor will run on a low settingeven when not needed for cooling to control humidity/fogging of windows? It kicks in stronger when it is needed for cooling?
also, maybe you could do something simple like cleaning your maf sensor with a spray cleaner.
i'm not sure which models have the variable ac compressor, and yes they are usually on at least a little. but i would just turn off the ac next time you get the lunging to eliminate that as a cause.
chadillac2000
42
09-13-2017 11:15 AM
