Westfalia Tow Ball wrong size
Old 08-02-2010 | 08:30 AM
Nova Invicta's Avatar
My Ride: F11 520d white, auto, professional sat-nav with internet, variable damper control, sports steering wheel, extended lighting, retractable tow bar, wing mirrors with dimming & folding, full electric seats with memory & lumber adjustment, etc.
I have a late E60 with the factory fit electric tow bar and have had it replaced by BMW after rear collison. The new tow bar was "chattering" with the Al-Ko 3004 stabiliser on my caravan so at first I thought it was the friction pads. Turns out the 50mm tow ball is actually 49.81mm and Westfalia have failed in their quality control I now have a aggrevation of convincing dealer that its a fault and needs replacing FOC.
Old 08-02-2010 | 05:32 PM
or_550i's Avatar
Good luck. You realize that you're pissing on about a 0.095mm difference on either side of the tow ball? I used my 50mm Westfalia tow ball to tow a US trailer that normally uses a 2" (50.8mm) tow ball. That's 0.4mm of side slop and my 4000 km drive was no problem at all.
The 'chattering' you are hearing is the tongue weight being too light and thus allows the trailer coupling to bounce on the tow ball. Put more weight on the tongue. This will force it to stay down and planted.
E60Japanese
03-12-2021 10:07 PM
E60Japanese
05-27-2015 04:25 PM
asinner
05-06-2015 07:03 PM
sportzfan76
03-30-2015 08:19 AM
E60Japanese
03-23-2015 06:23 PM
