Weight distribution
Old 09-25-2006 | 08:35 AM
dlevi67's Avatar
Originally Posted by BetterMakeWay' post='338394' date='Sep 25 2006, 04:22 PM
Maybe some parts are re-positioned in the heavier engine models?! I dunno...
Larger trasmission/diff/brakes; center of gravity of engine further back; electronics bits moved to the back. Once upon a time, the battery went in the back for the bigger models, and in front for the lighter ones - now I guess they are all so heavy it's in the boot by default!
We are not talking enormous amounts - 1% of shift is about 15-20 kg ; the whole difference in weight across the range is 190 kg which divided 50/50 is 95 kg -> only need to shift 70/80 kg...
Old 09-25-2006 | 09:28 AM
aybeesea's Avatar
So a passenger or a tank of fuel...
ABC
Old 09-25-2006 | 10:13 AM
hythe's Avatar
My Ride: 2005 BMW-Alpina B5 Touring #007, Malachite Green w/ Caramel Individual interior 1999 BMW 840Ci Sport Individual, Techno Violet w/ Champagne Individual interior
Clearly it's the higher number on the badge adding the extra weight in the rear...
Diff would make up a large chunk of it, I suspect, when moving up to the V8 models. I assume the V8s and 535d use a different diff than the "cooking" models?
Old 09-25-2006 | 10:44 AM
aybeesea's Avatar
I thought the 535d WAS the cooking model.
It uses chip fat for fuel.
OK so technically it's a "frying tonight" model.
ABC
Old 09-25-2006 | 11:39 AM
BetterMakeWay's Avatar
ABC
What are you talking about?
Old 09-25-2006 | 02:18 PM
Bimmer32's Avatar
They can't figure out where the weight distribution went, so they starting drifting and talking about fuel consumption and name calling . . .
Anyways, using more lightweight matter in the front offsets the heavier v8 and diesel. Didn't you guy learn that in physics? Add more aluminum to the front end (compared to the % of steel in the i6) and there you have it.
Old 09-25-2006 | 02:30 PM
aybeesea's Avatar
Looks like we have a volunteer interpreter for the UN...
From English to American!!
ABC
Old 09-25-2006 | 02:49 PM
Yeah but in a way that's making the L6 models heavy on purpose...from that judgment. And weight is the killer in any good car right?
Old 09-25-2006 | 10:43 PM
Bimmer32's Avatar
ABC
right on!!
Old 09-26-2006 | 12:49 AM
dlevi67's Avatar
Right. However, pressed steel is still cheaper than forged aluminium...
