the way E60 was meant to be
Old 08-15-2013, 02:35 AM
  #551
Blaz Bohnec's Avatar
My Ride: e60 530d 270hp remap
I just remembered guy remaping my car has 290hp+ on his 530d but he couldnt do it on mine, he mentioned something about electronics but i didnt ask what was different on his newer 07 model.
Old 08-18-2013, 06:21 PM
  #552
jay408's Avatar
My Ride: 08 550i E60
so quick question. Which slots do i put the pins in for the U.S. 2008 LCI model?
Old 08-30-2013, 11:42 AM
  #553
diz
diz's Avatar
Originally Posted by Cockers
Received my cable tonight, hooked it up with NCS Expert, and after a bit of faffing around with the dates so it actually recognised my car I have programmed the 'Sport' light on the display (as well as other goodies like digital speedo, door locks releasing on car stopping, heated seat on I drive etc) and I am well chuffed, thanks dbond for the pointers.
I have decided to buy the original 'sport' button and drill a hole in the existing plastic gear gator to give it the OEM look and feel. The more I think about it, I just think the best place for the button is on the gator!
Anyway I'll keep you all posted on progress.
good write up!!! only just came across this mod, have a LCI 535d and wondered firstly if you fitted an original Sport button and where you fitted it etc and secondly what kit you used to re-programme to get the Sport in the dash...wonderi8ng if an independent garage would be able to do this on there diagnostic?? although may come in handy if done myself as need to replace faulty head-unit and apparently need to recode second hand unit at a cost of circa £200 at main stealership
Old 09-03-2013, 11:00 AM
  #554
mmitev's Avatar
Anyone done this on a remapped pre-LCI diesel?
Any info/experience on how does it (or not) interfere with the remap?
Old 09-08-2013, 11:39 AM
  #555
tcuaviator's Avatar
My Ride: 2009 535i
Sport Button mod works well to stiffen up the steering on my 2009 535I. Installed a Z4 Sport Button on the center console. Had to modify the circuit board on the button to get instrumentation and on/off LEDs operational.
Attached Thumbnails the way E60 was meant to be-photo-1.jpg   the way E60 was meant to be-photo-2.jpg   the way E60 was meant to be-photo.jpg
Old 09-08-2013, 12:32 PM
  #556
b00sted415's Avatar
My Ride: BMW E60 M5
Model Year: 2010
Engine: S85
Nice and clean!
Old 09-18-2013, 12:19 PM
  #557
Kennethr's Avatar
My Ride: E61 2006 525d
Looks nice.
Im going to use this button on my pre lci. Did you get an oem plug for the button and do you have the partnumber for it? Not the button itself but the connector
Old 09-20-2013, 12:09 PM
  #558
tcuaviator's Avatar
My Ride: 2009 535i
I bought it off ebay used. The connector was on it but all wires were cut (didn't have a part #). The circuit board had to be modified IOT have both LEDs and button functional. You can solder wire direct to the pins if you disassemble it. This would allow you to modify it all at the same time to make it operational.
Old 09-27-2013, 09:36 AM
  #559
C_o_s_m_i_n's Avatar
So...
I want to do this mod on my 2008 E60 with manual transmision and no active steering.
In order to activate that SPORT indicator on dash what do i have to code?
From what i've read, in kombi i must set the following 2 parameters:
FDC_VERBAUT - aktiv
FDC_ID_MONITOR - aktiv
Is this correct?
Old 09-30-2013, 02:13 PM
  #560
BallyM5's Avatar
My Ride: BMW 530D M-Sport, Steptronic, Grey Metallic, Retrofits: Sport Comfort Black Leather, M-Sport Alu Cube Dash Trim, Shadow Line Trim, CCC Pro Nav, Full M5 Conversion, M5 Mirrors, Quad M5, 20" M5 Gloss Black wheels, AC High Panel, Internal Boot Release, Mods: Xenons, Carbon Fibre Roof, Dension 500, Drilled & Grooved Discs,
hi guys i did this wire mod today but i have wired it up to a switch that is fitted in my gear surround
also i have a m5 speedo fitted do i need to code the kombi to see a sport or power icon on the speedo or does the m5 speedo not have a sport or power icon
if so any idea which value thanks
Quick Reply: the way E60 was meant to be
