Water Pump Replacement/Compressor belt pulley?
My Ride: 2005 BMW 545i, Titanium Silver. Bridgestone 760s on Weds Bavaria II 18" wheels, standard sport pack size. Sport, AT. Latest job - NGK Iridium IX plugs installed.
Well I got a belt on - the old one. the new one would not stretch enough. I have spent 3 days fighting it, trying to make a tool to keep the belt in place, but with all the hydraulic hoses in the way, I just didn't have the leverage. My pulley doesn't look like the one in all the RA instructions and pictures I have seen - it doesn't have the flat area around the lip, and maybe the lip is smaller, and the belt just kept slipping off. hopefully this gets me by so I can get it to a mechanic. back to putting all the hoses back on now.
http://forums.5serie..._1#entry1207441
My Ride: Orient blue '05 545i, Sport/Premium Pkg, 6Speed MT, Xenon, Navi, Blue2th, PDC,
Regarding the hydraulic hoses - you need to take the mounting bracket out or at least take the houses out of the bracket (there is only one screw)
You must not have active steering, had a friend to help, or totally moved it out of the way. The tool is $145 thru my dealer but I had to order it. so I made my own for $5 (took two minutes to make) with the help of a hack saw. Then it took only a couple seconds to put the belt on.![](https://5series.net/forums/public/style_emoticons/default/angry.gif)
oh damn the cheezy plastic radiator drain plug snapped..back to parts tomorrow
![Bashwall](https://5series.net/forums/images/smilies/imported/bashwall.gif)
the serpentine belt, in contrast, was a breeze to put in. I guess they decided to do away with the tensioner to make room for all this hydraulic tubing...why does it have to be so long?
OK, the good news is that I was able to extract the broken drain bolt. Good thing it broke, otherwise I would have never known that only one of two o-rings were on the plug. The bad news..the pump was never the source of the coolant leak. I found the leak, but now I'm at a loss on what to do next. It's coming from a hole on the block itself. At least I did good on the pump install.
From all the diagrams, it would seem that I have a leak under the intake manifold, possibly from the O-Ring behind the water feed pipe.
That would probably be a task beyond my comfort zone.
I'm back to where I started.
![Help](https://5series.net/forums/images/smilies/imported/help.gif)
![Crying](https://5series.net/forums/images/smilies/imported/crying.gif)
Start learning to use you skills. Looks intimidating and I hope never to need to do it. Really hope this is not it but...
http://www.youtube.com/watch?v=UoCED1jyfL4
