Water is leaking near 'C' Pillar
Old Apr 22, 2012 | 07:15 PM
ponnu's Avatar
Its raining cats and dogs in southern CT, I don't usually park outside. I wanted to wash off the polen from my car, hence I parked the car outside in the rain for about an hour. When I took the car back to garage, I found the 'C' pillar (Passenger side) wet (see the pics). what is causing this leak? is it sun roof.
(My dealer also changed the rear glass's outer rubber beads about 2 years back). Any suggestions would be appriciated..
Sorry for the low quality photo, I used my iphone..
Attached Thumbnails Water is leaking near 'C' Pillar-photo-2-.jpg   Water is leaking near 'C' Pillar-photo.jpg
Old Apr 22, 2012 | 07:40 PM
jaycal3's Avatar
My Ride: 04' 545i, Sport Package, Black, Active Xenon, ARS, Aux Input '10 Tahoe, Black on Black, leather, Nav/XM, 20" tires, full body kit, power 2nd row, loaded '93 Jeep Wrangler, lifted 4.5", 33" meats, Rampage Recovery Bumper w/Tire Swing, etc 25' Aquasport Osprey, Center Console,2012 200 HO Etec
Probably your sunroof drains... a known problem.
Old Apr 22, 2012 | 07:59 PM
Shydee's Avatar
My Ride: E60 535i
Model Year: 09
Just had the same problem.
Had my drains checked n cleaned by the dealer, but then it still leaked.
So this time they changed the sunroof seal, sunroof caskett, and the whole interior changed where it left stained.( basically got me a whole new roof interior.
If your out of warranty, try o change the sunroof seal.
I had the leak on the same spot as you.
Old Apr 22, 2012 | 08:11 PM
louisrai's Avatar
My Ride: 2008 BMW 535i Silver - E60
I fixed my sunroof seal, the leaking didn't go away....
Old Apr 22, 2012 | 08:57 PM
Dc4rob's Avatar
I had the same problem happen when rolled through car the wash in my 530i
but it rained pretty hard the other day and no signs of leaks from that same area, hmm...
http://
Old Apr 23, 2012 | 12:12 AM
dR.jonezz's Avatar
My Ride: E60
I've had that same problem once and I think I just had the rear window little bit open and when I have alot of speed on the highway the water just flew there. So I think you guys dont have to worry about that !
Old Apr 23, 2012 | 01:53 AM
peachykonan's Avatar
I had the same issue when going thru a car wash. Sun roof seal replacement seemed to have fixed it for me.
Old Apr 23, 2012 | 03:53 AM
B767capt's Avatar
My Ride: 2008 M5 SMG
I would go to the trunk and look in the center area under the mat. A lot of damaged black boxes once water hits them. A common problem. Could end up being very expensive. Lucky you caught it.
Old Apr 23, 2012 | 04:20 AM
phlfly's Avatar
My Ride: 07' BMW 550i
I had same spot, but when I found it it was already dry, and blue color. I guess it was from the wash. It's raining for day in N.VA but same spot it's still dry. But I replaced sunroof seal.
Old Apr 23, 2012 | 04:32 AM
ponnu's Avatar
http://
Did you drive while it was raining hard?; I never noticed the leak if the car is on the move during hard rain.
