water dripping from sunroof when opened
Old Sep 9, 2017 | 01:18 PM
BrownPower's Avatar
My Ride: e60 535i JB4+DCI
Thanks. I'll get it done
Old Sep 10, 2017 | 04:26 PM
BrownPower's Avatar
so there are 2 seals at real oem for the sunroof which confuses me a bit.
RealOEM.com - Online BMW Parts Catalog
am i supposed to choose #8?
Old Sep 10, 2017 | 05:16 PM
seanjordan20's Avatar
Engine: 3.0 B58; 3.0 M54
That diagram looks confusing. What you need is the strip around the roof cutout not around the glass.
https://www.ebay.com/itm/351738217301
Old Sep 13, 2017 | 11:22 AM
BrownPower's Avatar
i ordered the seal.
one last question. the sunroof glass also has some sort of hard rubber, will that need to be replaced eventually also? or is that permanent as part of the glass itself?
Old Sep 13, 2017 | 12:47 PM
The weather seal is what you ordered. Which seats against the glass seal. You ordered the part needed. If you have any questions about parts realoem is the site to go to. I think the seal on the glass is permanent but don't quote me on it.
Old Sep 14, 2017 | 08:53 AM
NoQuarter's Avatar
Engine: N54
The part on the glass stays as is.
After you replace the seal, you need to re-initialize the opening and closing process so that it relearns the proper closing force.
Hold the open button continuously until the sunroof opens completely. Then I think you keep holding it then the sunroof closes completely - something like that.
